Need A Lot Of Help, Bad!!!!!!!!!
The oil pressure sending unit may have come in contact with the firewall when the engine was raised, the wiring or sender could have been damaged.
Engine temp sender is on the front of the engine though.
If someone was reaching down to the oil cooler from on top of the engine, they may have knocked the wire off, but that is about the only way I could see causing a problem there.
i had the same issue a while back and what it ended up being was the plug behind the gauges in the dash its just a few screws it had just somehow worked itself loose and plugged it back in and bingo!workin once again.they are both on the same plug so that may be what it is.cause i went through and replaced a bunch of stuff and it only took a few minutes to fix the underlying cause.just another idea for you to try.hope it all works out for ya
on
About the low oil pressure. If you can't get a reading off the stock gauge, than get a mechanical one and install that even if only as a temporary measure. We had problems with other trucks not showing oil pressure or showing wrong readings, and a simple mechanical gauge will rule out any internal issue if it reads properly.
