it all depends on what truck you are talking about.
if it is a F150, there is a lot of work required to put a diesel in, due to the weight of the engine. if it is a F250 or F350, it will be a lot easier, due to the stronger frame.
another thing you need to remember is you are not just replacing the engine. if you have an automatic trans, you will need a diesel trans also. if a manual trans you will need at the least a bell-housing and complete clutch setup.
Id say like the rest, what truck is it in and what do you use it for.
If its just a half ton truck and your not pulling anything, Rebuilding the gassers probably not a bad Idea. Alot cheaper route, expecially since diesel is quite a bit higher than gas. I had an old 1983 ford econoline with a 4 speed manual with a 302. I could turn out almost 18 mpg in that sucker (I don't remember what rear end it had though) I still don't know why I sold it but it ran great. Didn't pull nuthing with it or need alot of power so the 302 worked excelent.
For the trouble a swap is worth, Unless you really like the truck setup and body you have, then it would definatly probably be cheaper to find a diesel rig if you need to go diesel. I have been wanting to put a cummins in my 1/2 ton chevy but costing nearly 8,000-10,000 for everything, I havn't descided yet If its worth it, probably not. (i was going to geat a near new high output cummins from the salvage and the kit made for the swap, then I need a tranny, tougher rear end, beaf up the front suspension, ect) Alot of work to do. But hey, a little work never hurt anyone.
What year did F250's get a different frame and front axles?
F350s have had a heavier frame forever but F100-F150s and F250
did share kingpins-axles on the older trucks and the frame was the same.
I don't think I'd waste the time or money on that swap. If you can get HONEST mileage figures out of the Dodge owners you'll find your SBC EFI gets dang near as good of mileage.
Cool: yes, practical: no.
The truck is an F150. The fame is going to get beefed up for offroading anyways. the 302 is currently getting 15mpg highway and around 10 in town if i don't beat on it. The reason i was wondering about diesel is one of my buddies does bio diesel and has a filter system so i could get it for nest to nothing. I also thought of just buying another truck, but my price range is low and i'd love a diesel.
All due respect....the f150 is not a real truck....I have a buddy that went down the road you're going, he wouldn't listen to any one....spent 20 plus grand on the f150, got $7000.00 when he sold it!
Now if your into projects and have tons of time and money and just want to say it can be done and you did it, well....good for you.
I see older 84-93 Diesel's selling here for under $3000. with 150k miles on them that is a really cheap truck.
And yes they will run on about any kind of oil.
All diesel trucks, F250 and F350 have F350 frames.
The light duty F250 has about 1/2 the frame thickness and strength.
It would take some serious work to get a 150 frame to hold a diesel engine weight and torque.
