I want to replace my headlights because the lenses are trashed (even after I cleaned them) Does anyone know of snap in replacements available ? I have looked and not found what I was looking for. I want something I can just swap.
I am also interested in the same thing for the turn signals, parking lights (on the front) and the lights on the back. Looking at LED.
02-04 headlights and turn signals are a direct swap as long as you get all the adjustment screws with them. 05-07 lights also fit but require cutting the header panel. No idea on tail lights, never looked into it.
I swapped in a set of aftermarket headlights and corners on my 99. As for tails I switched to LED tails from eBay. Everything is pretty easy. Hardest part was getting the old headlights out.
Originally Posted by billpinsc
I was wondering are the plugs the same if i wanted to change from 03 to 05-07 lights?
Nope. 99-04 are 9007 bulbs and 05-07 are 9008. However, if you do want to switch to the newer headlights you can purchase the 9008 pigtails from DFuser.
I can check the packaging tomorrow on the headlights and see if there's a brand name on those but I can't tell you off the top of my head.
As for the corners, they're DEPO branded.
Bought both as a set on eBay for about $130. Great deal and the headlights and corners have about 1.5 years on them and they still look good and seem to be holding up well. Only thing is that the aftermarket headlights don't seem to have as much output as the stock headlights. I don't know if its the bulbs (I'm using the ones they sent with the headlights) or if its something in the light housing itself.
