Sponsored by: Kumho
Stud Removal
Old Dec 3, 2002 | 02:59 PM
MustangGT221's Avatar
MustangGT221
Stud Removal
I have some Firestone Winterfires, and I was wondering if it's possible to have the studs removed. I bought the tires with the studs because on my 2wd I needed the extra traction for ice to get going, but I don't need that on my 4wd. I have very poor traction on dry pavement because of the studs, and was wondering if I could remove them? Thanks.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 3, 2002 | 05:18 PM
crazyford's Avatar
crazyford
Stud Removal
im not sure but if i were you id call a tire store and ask them.
Old Dec 3, 2002 | 05:39 PM
Steve_Uzi's Avatar
Steve_Uzi
Stud Removal
Poor Traction? Thats hard to understand...I say run them
I know in Massachusetts, you can only run studded tires from Nov 15-Apr 15, then its illegal.
Old Dec 3, 2002 | 08:21 PM
fordmaniac21's Avatar
fordmaniac21
Stud Removal
you should be able to pull them out with a pair of dykes and or pliers. i know they are a pain in a new tire but i have done a few on older studded tires back when i worked at a tire shop. it mey take a while to get em all out.
'75 F-100 4x4, 4" lift
35x15.5x15 super swamper TSL/SX
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
Old Dec 3, 2002 | 08:24 PM
superrangerman2002's Avatar
superrangerman2002
Stud Removal
[updated:LAST EDITED ON 03-Dec-02 AT 09:30 PM (EST)]yeah, you can remove them, but it will be a real PIA.
use lots of wd-40, and a good needle nose vise-grip.
If you can, try to do it with the tires at room temp (like one tire at a time in a heated shed if possible), it will make it alot easier.
Also try to squirt wd-40 onto all studs and let it soak in a bit.
good luck!
Old Dec 3, 2002 | 11:37 PM
MustangGT221
Stud Removal
On dry pavement the studs are very much in contact with the road. Since a metal surface has a lower coeficient of friction over rubber, it doesn't have as much traction as a rubber tire without studs. With my 32" BFG's, I can only spin the tires if i'm accelerating out of a corner. I can get them to squeak a little on a hard straight line acceleration but unless I use the clutch hard I can't spin them. With the studded tires, I can't even go full throttle in 2nd gear without breaking traction, and if I am going about 30 I can get the engine to 3k or so and dump the clutch and spin them pretty fast only using about 3/4 throttle in 3rd gear ha. It's pathetic. Seems like a tough job. I'll have to call my tire man and see what he'd charge me. I know these studs have square back plates so I don't know if I can pull them out with a pair of pliers. I will try, but we'll see. Thanks for the suggestions. Also, you are correct about the massachusetts studded tire law.
Old Dec 4, 2002 | 12:13 AM
superrangerman2002
Stud Removal
almost every stud has some kind of back plate, be it square or round. It will suck pulling them out anyway you look at it.
my .02
Old Dec 4, 2002 | 12:20 AM
superrangerman2002
Stud Removal
Korbe
Jan 8, 2017 04:57 AM
MustangGT221
37
Jun 16, 2012 09:18 AM
MustangGT221
Offroad & 4x4
37
Dec 15, 2002 11:03 PM
MustangGT221
Oct 28, 2002 10:16 PM
MustangGT221
Oct 11, 2002 11:41 PM
