Hope i used the right ELC coolant?
Hey everybody, i picked up some Prestone ELC the other day and flushed and filled with 4 gallons and some distilled water. Everything looks great but after looking on their web-site i see a heavy duty ELC in a black bottle, i purchased the yellow bottle. Here,s the link .Prestone :: Products : Antifreeze/Coolant Did i purchase the wrong coolant??? I got the first yellow one and if you scroll down you'll see the heavy duty coolant. Thanks..
If that's considered a "Universal Coolant", check out what Gooch has to say about them in post number 4, second to last sentence, in this thread: Gooch's Coolant Info: Post #4
"Not to be used - Dexcool, Universal coolants, All-makes-all-models, etc."
Stewart
Stewart
Mike, in checking further, Gooch has this to say about the coolant you used:
"... do not use the Prestone Extended Life (All makes-all models). It is not a diesel coolant, and was never inteded to be a diesel coolant. Prestone will even tell you that if you call them.
Prestone makes an excellent extended life diesel coolant. It is called Heavy Duty Extended Life Coolant. It will be red coolant in a black bottle. They also make an excellent conventional, pre-charged coolant. But it will have a shorter live and still need to be tested for SCA. It will be purple coolant in a black bottle.
Check them out here: Prestone :: Products : Antifreeze/Coolant
In NJ, you might find them, or order them, at a Carquest, Action Auto Supply, Tri-State, VIP, or Consumer Auto Parts store."
Source: Post number 12 in the same thread link in my above post.
Stewart
Stewart
When I did my water pump replacement last year, I studied his posts. That's one reason I was able to contribute to Nicks water pump thread.
Stewart
I used the first thing on this page..
Google Image Result for https://ohe.cat.com/cda/components/securedFile/displaySecuredFileServletJSP?fileId=145634&languag eId=7
I'll be honest, I rarely go to TDS, but when it comes to ANYTHING coolant related, I do a search on Gooch's posts and threads. He KNOWS coolant stuff.
Stewart
Stewart
You're very welcome!
Stewart
