Yeah, the older trucks (up to the early 99) needed the 120* bent extension. If you have a late 99 or newer, just a short piece of 3" ID PVC (which is 4" OD) will work, or a 3" long piece of 4" OD exhaust pipe will work as already mentioned...
EDIT: FWIW, you can fit the 6637 neck inside the end of the intake tube with a little work at it. I ran mine like that for a year before I switched to a short piece of exhaust pipe. You do have to watch it though -- it can loosen up over time...
If you need a bent peice, go to an electrical supply house and get a 3.5" EMT 45* elbow, this has a OD of 4". You can mark and cut it to what you need.
Someone had made a thread warning about soing it that way. they said that they found it was pinching the bottom of the filter and cause a passage for air...
Heres the thread https://www.ford-trucks.com/forums/7...7-warning.html
