I use never sieze, I've always been told lube or oil is bad, because it would be easier for them to work their way off. Probably a myth, but I have never had any problems.
Anti-seize on everything: lugs, exhaust bolts, oxygen sensor, body mounts, leaf spring bolts; pretty much any machine-threaded fastener.
http://www.webphotos.com/list_photos_edit.asp?mi=1&smi=1&a=13217
[updated:LAST EDITED ON 30-Nov-02 AT 03:09 PM (EST)]The lugs stretch the studs so that they "clamp" the wheel to the mounting surface. The stud can be stretch to a certain limit, beyond which it will fail. If you torque a lubed nut/stud to the same torque as a dry one, the lubed one will be stretched more, increasing the possibility that it will snap.
The reason they give you a dry reading is because that's how it's designed. Dry fasteners have less of a tendency to back off with vibration, and a dry thread can give fairly consistent readings. A lubed thread will give different readings depending on the type and quantity of lube.
I've never heard of problems with lubing them, that's just the technical explanation. But I think if you keep them dry and torque them as recommended, that's best.
FWIW: Ford itself sells lube for studs in a squeeze bottle. I think it is graphite based.
On the older Ford trucks and vans, say 1979, with the two piece nut you were suppose to put a drop of oil on the nut, not the stud. Maybe this is a hold over warning deemed worthy of including.
That is what I have...the two-piece nut.
The owner's guide does say to put a drop of oil on the nut; but to not put oil on the threads.
Thanks for the responses.
I too, use anti-seize on the lugs. Never had a problem; no loose wheels or broken studs. I do use the proper torque (80-90 ft lbs), and tighten in a criss-cross pattern. The pattern is very important, in my opinion.
00 Explorer Sport 4x2, 4.0 ohv, 5R55E, 3.55 diff
78 Bronco Ranger XLT, 351M, 4-sp, Trailer Special
Anti-Seize here too!! Works great... always a can laying around somewhere in the shop... Two piece nut... Is that the nut with the washer attached to it??? >o
Ray
Looks like a lugnut with a washer put on the rim side. Most often found on the (older and) heavier duty axles, I think they used them on vans too. They are often mated with a fine threaded stud which when rusty can take forever to take off even with a strong 1/2 impact gun.
Once worked on a truck that had one left hand threaded stud on two of the wheels. I could not budge the lug for anything, even with my 600 ft lb impact. I then invited the tire guy for a go at it with his 3/4 impact. Nothing! Then I started going back and forth and it loosen in the wrong direction. I do not even know where someone found a left handed stud, never mind lugnut! Never can tell what you will find on a 20 year old truck.
I am just surprised that the stud never broke, it must have been 100% Ford tough!
