edge evolution programmer with BD tune
Old Oct 28, 2008 | 07:29 PM
F350-6's Avatar
F350-6
Originally Posted by Izzy351
Where did you get all those other codes?? I don't see where he posted them.
I called on of those psychic 800 numbers and got them
Actually he posted them here https://www.ford-trucks.com/forums/7...-up-today.html
I saw that thread, but not this one. I sent a PM to Scott asking him to merge the two so we wouldn't get confused.
Old Oct 28, 2008 | 07:34 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I thought the same thing Joe. I just let Chris do his thing, and it always works out. Thanks Chris.
Izzy351's Avatar
Izzy351
Aaaahhh sooo. I didn't see that one... I still would make sure your boots are in good shape. Turbo could've crapped out, but let's hope for the easy fix.
Old Oct 28, 2008 | 07:35 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by F350-6
For future reference, it might be more helpful to update info in the same thread
Right you are. I merged the other thread into this one.
Old Oct 28, 2008 | 07:42 PM
F350-6's Avatar
F350-6
If I had known Scott would have been that quick, I would have just asked you two if you were blind and had you go back and read the thread.
Thanks Scott. Looks like we were all confused on this one.
Old Oct 28, 2008 | 07:54 PM
cookie88's Avatar
cookie88
FTE Emeritus
I probably wouldn't have noticed it if you hadn't pointed it out Chris.
Old Oct 28, 2008 | 08:25 PM
miller_feed
WOW, I say, let the hair go with the hide. All good.
Old Oct 28, 2008 | 08:50 PM
Izzy351's Avatar
Izzy351
Thanks a LOT, Chris!!! I already know I'm losing my mind -- don't need any help!
Old Oct 28, 2008 | 08:53 PM
F350-6's Avatar
F350-6
Just trying to help you along. I've found it's much better to have already lost it and be living in a fantasy world before your daughter gets too old. Makes life much easier to deal with.
Old Oct 29, 2008 | 09:24 AM
mcgyver5150's Avatar
mcgyver5150
OK....
1. Airbox was described to me as "killer" by a local diesel shop because it had a tendency to "dust the motor" -didn't seal or flow well, and had poorly designed cover latches. Was told that even Ford had a campaign to replace all the early boxes
2.As for smoke color...I'm getting very dark black smoke when I really mash the throttle
3. The chirp sounded alot like a belt squeal (but very quick -like less than a full second) and I checked my belt...no problem and even put on new idler and tensioner- and it still did it. Then it went away about a week later and thats when I noticed a drop in power
4. Turbo has been checked...I pulled it off and examined the impeller shaft and wheel for damage and any bearing failure...None Found
5. NO...I don't have gauges yet...Yes I know I should have them and am going to try to get a good deal on some while I am at the SEMA show next week.
6. I did have a shop put my truck on their scantool and even they were doing some headscratching and thought that it might be an issue with the programmer. They cleared the codes and took a reading KOEO and said the map sensor reading was off the chart with out even starting the truck.
Old Oct 29, 2008 | 09:33 AM
Izzy351's Avatar
Izzy351
Good news on the turbo!
A good dose of black smoke when you mash the throttle is normal with a tuned truck. It should clear up quickly though. If it doesn't, it means the motor is starved for air.
What kind of OBA did you use? Electronic or the air pressure regulator type (like the ITP OBA that I have)?
mcgyver5150
DANG!!!!
I really screwed up the new post....put it where I shouldn't have ...
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">OK....
</TD></TR></TBODY></TABLE>
Old Oct 29, 2008 | 09:35 AM
  #28
mcgyver5150
Izzy...whats an OBA?
Old Oct 29, 2008 | 09:44 AM
  #29
Izzy351's Avatar
Izzy351
Okay, I may be confusing myself. I thought I read in one of your posts where you had some kind of overboost fooler, but I think that was someone else now...
But I'm starting to think you simply heard turbo surge. That can happen on a stock truck towing, so the fact that you heard it towing with your chip makes it that much more likely. I doubt that's related to your power loss however. We really need to know what your boost/EGT numbers are so we can narrow this down. It could simply be a bad MAP sensor, too. They go bad from time to time and would explain the power loss. The PCM uses that for fuel mapping so it could be cutting back based on assumed values, thus your power loss. We need some more info to get to the root cause.
Old Oct 29, 2008 | 09:46 AM
  #30
Izzy351's Avatar
Izzy351
SHOOT!!! The P0475 may be telling us the EBPV is stuck!! I just went back an reread your codes... Check that next!
That would cause loss of power & boost, and excessive back pressure. It's common for those to stick, too. You probably got some cold weather down there and the truck tried to close the EBPV and it stuck for some reason...
