Pulling the glowplugs
Old Oct 27, 2008 | 08:26 PM
skyrider4000's Avatar
skyrider4000
I have a 99.5 PSD, nightmare staring in cold weather. I'm planning on just changing out both the relay and the plugs, instead of trying to test each piece individually. I HAVE read some of the other threads relating to glow plugs and the GPR..
My main question is is, do the glow plugs usually come out without too much trouble? Or have many people had problems stripping them in the heads while trying to get them out? Any other tips would be super too.
Thanks a lot
Old Oct 27, 2008 | 08:43 PM
F350-6's Avatar
F350-6
I would test the relay first to make sure that's not your problem. Should only take 15 seconds to test the relay. If you have to pull a valve cover(s), go ahead and replace all the ones on that side.
Nothing too complicated. After you break the glow plug loose (deep well socket) take the socket off. If you try and remove the glowplug with the socket on there, it gets caught by the rocker arm.
Here's a link for you to do some more reading. https://www.ford-trucks.com/forums/4...ke-thread.html
Old Oct 27, 2008 | 08:45 PM
jdecker88's Avatar
jdecker88
I'll do the seaching for you hehe https://www.ford-trucks.com/forums/4...ke-thread.html this seems to be a good write up about them.
Edit
You beat me to it Chris lo.
Old Oct 27, 2008 | 08:46 PM
mjlewis's Avatar
mjlewis
our local PSD guru Guzzle wrote an awesome article on how to replace the GPR.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Oct 27, 2008 | 08:49 PM
skyrider4000
Thanks guys
Old Oct 27, 2008 | 08:50 PM
jdecker88's Avatar
jdecker88
NP Skyrider.
zeppelingto
Feb 1, 2022 09:23 AM
IDI-Charlie
16
Feb 20, 2014 03:09 PM
07 F250 Aggie Mobile
Apr 30, 2012 09:25 PM
David85
Nov 24, 2010 10:40 AM
bigbubba87
Jun 27, 2010 04:28 PM
