Glow Plug Harness Changeout
Old Apr 30, 2012 | 04:44 PM
07 F250 Aggie Mobile's Avatar
I have a 2007 6.0L and my CEL was throwing trouble codes for #2 and #5 glow plug circuits. I bought the glow plug removal tool on e-bay and bought two new harnesses from the dealer and performed this changeout this weekend. Good thing I also bought two new glowplugs, cause after changing out the harness, the CEL trouble code was still there. I then changed the glow plug and PRESTO, no codes!! I tried to test the old plugs by hooking them up to my jumper cables and they did not get hot at all. Not too bad of a job considering. Is there another way to test glow plugs?
Old Apr 30, 2012 | 05:13 PM
bismic's Avatar
bismic
you can disconnect the glow plug harness and test the resistance of each plug. Each plug should read 0.1 to 2 ohms resistance. The harness should read 0 to 1 ohm resistance.
Old Apr 30, 2012 | 06:06 PM
F-250HD's Avatar
F-250HD
Don't "light them off" too long without being screwed in the block to dissipate the heat, or you will fry them. I just checked them on my little FORD diesel tractor, they were each about 1.3 ohms and glowed when "hotwired".
Old Apr 30, 2012 | 09:25 PM
wgcdc's Avatar
wgcdc
How difficult of a project is this? I am getting P0673 #6 GP. As I understand, you need to remove the wheel and fender well to access the GP and harness? How long did it take you to make these repairs?
LSO1123
Jan 28, 2018 11:16 AM
wabassguy1
Jun 6, 2017 04:48 PM
2civicrr
Dec 13, 2014 07:42 PM
the_auto_tech
Aug 21, 2013 08:45 AM
Mattb60
Aug 1, 2013 09:21 PM
