65 Intrument cluster
Old Oct 27, 2008 | 12:28 PM
carhartted's Avatar
carhartted
I have a 65 f350 and I am looking at changing the instrument cluster to get more gauges. I have what I believe is the optional ammeter and oil pressure gauge. The pictures I have seen of other gauge clusters show the speedo in the middle with a stamped round area on either side where the optioal gauges go.
Is there a gauge panel that does not have the stamped round area. Where the horizontal lines go all the way accross. I would then put four extra gauges in.
I just picked up a Cummins 5.9 and plan on swapping it in. I would like to keep the cab as clean as possible but I need a place for a boost and exhaust temp gauge.
Thanks
Old Oct 27, 2008 | 12:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Take a look here: carolina-classics.com / catalog / Pages 58 & 59.
There different "custom' dash panels are shown on page 58, the gauges are shown on page 59.
800-598-4211 is their phone number. Carolina Classics is located in Durham, NC.
Old Oct 27, 2008 | 12:53 PM
carhartted's Avatar
carhartted
Thanks
That is close to what I was looking for.
Old Oct 27, 2008 | 04:01 PM
daveengelson's Avatar
daveengelson
Not clear which type instrument cluster trying to locate. Have a 65 F100, originally had the round speedo, with the oil and Alt. idiot lights. Purchased a cluster on ebay that has the round speedo with the 2" round Amp. and Oil pressure gauge on each side. Eventually installed the circuits, now have both, idiot and gauges. If looking for simular, occasionally see them on ebay, currently there are a couple sweeping and few with the round speedo on auction.
Old Oct 27, 2008 | 04:48 PM
NumberDummy
Optional on 1961/66's without the sweep speedo.
1966/77 Bronco's use a similar round cluster. Instead of idiot lights for the oil and amp gauges, it has all four gauges enclosed within.
Old Oct 27, 2008 | 06:27 PM
carhartted's Avatar
carhartted
I am looking for a round speedo cluster without the optional gauges and without the round indents on either side of the speedo. I don't think they made one apparently.
Old Oct 27, 2008 | 08:22 PM
gangstakr's Avatar
gangstakr
Take a look at my gallery check out my dash. Is this what your looking for?
Old Oct 27, 2008 | 09:57 PM
Customcab's Avatar
Customcab
I understand the type of cluster your looking for, not wnating a round indention look; but for a OEM look I reccommend using a F600 speedo, yeah it got several additional holes; but its factory with rpm & air pressure. Got a localbuudy who's usually has one on ebay for sell; if interested I could ask him the next time I see him.
Mitch
Old Oct 28, 2008 | 12:27 AM
carhartted's Avatar
carhartted
That is exactly what I am looking for. I want it to be smooth on both sides of the speedo so I can put 2 gauges on either side. Is that a stock peice or did you fabricate that?
Thanks
Old Oct 28, 2008 | 12:44 AM
carhartted's Avatar
carhartted
Mitch
Is it like this one. It says it fits 67-72, but it looks like it would fit. Can it be modified?
eBay Motors: 1967-1979 Ford F600 Dash Panel for F100 F250 F350 Swap (item 260305166413 end time Oct-30-08 21:06:42 PDT)
Old Oct 28, 2008 | 08:23 PM
bluestang65's Avatar
bluestang65
I used that style cluster in my truck. I put the F100 speedo in the bronco cluster to retain the original speedo rather than the bronco one. Looks completely factory and wiring should be a snap.
Old Oct 28, 2008 | 10:15 PM
modeleh's Avatar
modeleh
The early bronco speedometer was also available in kilometers per hour for Canadian Broncs when Canada went metric around '76/'77. These registered to 160 km/h. A guy in town who used to race a Bronc in the Baja500 used to get them and recalibrate them for MPH, so he'd have a factory appearing 160 mph speedo. Probably not what most of you are looking for, but I just thought I'd throw that out there. I see Carpenter has some km/h speedos in their catalog.
Old Oct 29, 2008 | 12:21 PM
Customcab's Avatar
Customcab
Thanks kinda the same style; but If I remember right the rpm & Air Psi gauge where in larger holes.
Old Oct 30, 2008 | 12:00 AM
gangstakr's Avatar
gangstakr
Look at this ebay item. To bad it's expensive.....or not. Depends what you want. Or how bad you want it. Item number: 300269805569
Old Oct 30, 2008 | 12:27 AM
NumberDummy
Not to me it doesn't. It doesn't look anything like a 1961/66 cluster. Can it be modified?
eBay Motors: 1967-1979 Ford F600 ( HUH??) Dash Panel for F100 F250 F350 Swap (item 260305166413 end time Oct-30-08 21:06:42 PDT)
This info is totally in-correct and mis-leading.
1967 F500/750: C7TZ-8104320-B .. Instrument Panel
1968/72 F500/750: C8TZ-8104320-B .. Instrument Panel
An instrument cluster that fits a 1967 F500/750 will not fit a 1968/72 F500/750. None of these F500/750 clusters will fit any 1967/72 F100/350 panels, either, because...
These two panels are different than the F100/350 panels, and there are 3 different ones of these: 1967 only (C7TZ-8104320-A) / 1968/69 (C8TZ-8104320-A) / 1970/72 (DOTZ-8104320-A).
None of these instrument panels, or instrument clusters are the same as 1961/66's.
So...an instrument cluster from a 1967, or 1968/72 F500/750 will not fit a 1961/66.
