no heat
Old Oct 30, 2008 | 05:52 PM
Bigredfan's Avatar
Bigredfan
again, thanks everyone. i hope that this thread does help someone else as it has helped me.
Old Jan 26, 2009 | 03:02 PM
Mitchissippi's Avatar
Mitchissippi
I might have missed this, if was discussed. Does the cable running from the dash operate a door in the box under the hood? Directing air from the fan either thru the heater core OR thru the cooling unit?
Old Jan 26, 2009 | 04:36 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by Mitchissippi
...cable running from the dash operate a door in the box under the hood?
Yes. :)
and
Yes. :)
But most of the time (while the hot water is going through the hear core and
the heater is "on") the lever will be part way directing part of the air over the
heater core and part will either be vented air from outside or recirculated air
from inside depending on whether the flapper door is closed or open (that
you can see there) by the passenger's foot space.
At least that's how it works with "factory air".
Alvin in AZ
Old Jan 26, 2009 | 07:18 PM
dentside79's Avatar
dentside79
Got to be the heater flow control valve found on the 5/8" hoses running to and from the coil. See if the vacuum line running to it is ok and connected on both ends (one end to the valve, the other to a good vacuum port usually on the vacuum "tree" behind the intake). If you have a vacuum leak in this hose, this may be your problem. The valve may also be bad and leaking vacuum pressure.
medic2439
1997 - 2003 F150
Jan 26, 2011 05:56 PM
rrumba
28
Jan 27, 2009 08:28 PM
JNKDad
Oct 26, 2007 09:03 PM
Sheemie
Nov 30, 2004 11:30 AM
fgallow333
Jan 9, 2001 07:23 AM
