Poor heat inside cab
Old Oct 25, 2007 | 02:01 AM
JNKDad's Avatar
JNKDad
I was looking for a thread that might help me with my van. The engine temp is ok and I just put in a new fomoco t-stat. Still not enough heat at feet. The van has both front and rear heat. Coolant temp was 190 @ radiator cap opening.. the heat hose sems hot going in but cool coming out of heat core.. Could the core be plugged. any help is greatly appreciated ,thanks
Old Oct 25, 2007 | 07:44 AM
PLC7.3's Avatar
PLC7.3
Core could be plugged..... try back flushing it. Also make sure the blend door is closing all the way.... that is the temp hot/cold ****........ when turned to heat there should be a thud..... like a door closing.
Hot coolant in is from head.....cold out to water pump....
Old Oct 25, 2007 | 10:52 AM
JNKDad's Avatar
JNKDad
Checked the blend door and found it was held open by about an 1/2", readjusted and no change, I will try the back flush after kid drop... thanks
Old Oct 25, 2007 | 11:43 AM
matts156's Avatar
matts156
Was there a foam seal on the blend door? Sometimes that foam rubber deteriorates and enough cold air gets through to make the outlet air colder. Plugged core is also a good possibility. Disconnect both ends when you flush it so all that junk doesn't go back through your system.
Old Oct 25, 2007 | 08:24 PM
faststang94's Avatar
faststang94
ive seen plugged heater cores that flow perfectly. dont ask me why or how, but ive seen it for my own eyes. heater core is cheap anyways and easy to replace id just go ahead and replace it chances are thats what it is
Old Oct 25, 2007 | 09:41 PM
JNKDad's Avatar
JNKDad
well I forced compressed air through the heater coreand am now getting more heat so I think I will just install a new one. Does anyone have a discription of how the coolant flows after the front heat core. My guess is that it tees back to the rear then returns to the ??? I havnt crawled under it yet due to the snow fall lately. Its getting cold out there
Old Oct 26, 2007 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Coolant supply from the passenger side head.
Coolant return is to the water pump.
Skip1970
Mar 3, 2015 02:39 AM
PStruwing
Feb 28, 2014 06:14 AM
miker73
6.4L Power Stroke Diesel
Feb 13, 2014 09:48 AM
dale75502
Aerostar
Feb 10, 2014 10:48 PM
Cube1000
Dec 29, 2011 10:20 AM
