Help with axle ID
Old Oct 26, 2008 | 08:21 PM
tenforty_2's Avatar
tenforty_2
Help with axle ID
I know........another axle ID thread ! I have spent 2 hrs looking for the answer and i am still not sure what I have. I am looking at an axle in a 1986 F350 2wd DRW. Vin= 1FDJF371XGNA40694 AXLE TAG = V190B & 10 10 2 6A29. What is the ratio, Dana 60, 70 or sterling? I am getting different answers from different sources. Thanks for the help!
Old Oct 26, 2008 | 08:28 PM
Franklin2's Avatar
Franklin2
If it has the oil fill plug in the back cover, it's a Dana. If it has no fill plug in the back cover it's a Ford/Sterling.
The VIN won't tell you much, but the sticker on the door jamb will have a rearend code. The axle tag should tell you what you have, but I dont have the decoder for that.
The only other thing I know is that if this is a chassis/cab, the rearend will not fit under the dually pickup. The dually pickup rearend is 4 inches wider.
Old Oct 26, 2008 | 09:02 PM
tenforty_2's Avatar
tenforty_2
Sorry I left out the axle code from the door (=65). I will look at it again tomorrow regarding the oil plug. I would be putting it in a SRW truck.
Old Oct 27, 2008 | 03:04 PM
CDF302v8's Avatar
CDF302v8
Code 65 is a Ford axle with 4.10's.
Old Nov 2, 2008 | 06:14 PM
tenforty_2's Avatar
tenforty_2
No fill plug so I guess it is a sterling.
BruteFord
74
Aug 21, 2016 09:55 PM
abosely
Mar 27, 2016 05:37 PM
uglybus
Aug 12, 2014 10:10 AM
thundersnow70
18
Jan 5, 2014 08:19 PM
driveguy
Mar 14, 2012 09:30 AM
