Air Suspension Question
Old Nov 5, 2008 | 02:21 PM
Bigfootmarine's Avatar
Bigfootmarine
Air Suspension
Thanks for the response. I tried sitting in the drivers seat, with all doors shut. The pump is working,but it would seem the air isn't getting to the rear suspension. I contacted Air Suspension and they suggested I check the plastic connections since they can become brittle and leak. If that isn't it,
must be the solenoid.
Old Nov 5, 2008 | 06:29 PM
zeuss's Avatar
zeuss
When you're back there, look at the bags. I think you can shut the compressor off after it vents and jack it up and let the rear end hang and get a good look at them to make sure they are not rotting anywheres.
Old Nov 6, 2008 | 02:04 PM
Bigfootmarine
Air Suspension
I took Eddie's (American Air Suspension) advice and checked the connector on the air line (near the master brake cyclinder) and sure enough, the connector was cracked and the line seperated. I have just ordered a part for less than $10 that probably caused all the failure of the rear air-bags to inflate. I think my compressor was bad, so replacing it was a good idea.
beeser
Oct 11, 2013 10:07 AM
karljay
Apr 14, 2012 03:47 PM
white_2kgt
Electrical Systems/Wiring
Mar 22, 2006 12:05 PM
Scavenger
Oct 14, 2002 10:46 PM
