side gear replacement
Old Oct 25, 2008 | 03:18 PM
Glenn O's Avatar
Glenn O
Hi guys. I have a 28 spline carrier out of a 9 inch ford center chunk that I want to remove the side gears and install 31 spline side gears in. This is a 4 pinion open differential. Have any of you done this or know if this can be done. Ive heard of it being done but I dont know how to split the carrier to gain access to the spider and side gears. Any help or suggestions is greatly appreciated.
Old Oct 25, 2008 | 05:30 PM
mark a.'s Avatar
mark a.
It won't work. The holes in the carrier are too small for the bigger axle to pass through.
Old Oct 25, 2008 | 09:47 PM
Glenn O's Avatar
Glenn O
Thanks mark a. I was wondering that myself. I have another carrier that is 31 spline but I don't know how to take it appart to gain access to the internals. It is some kind of locker because if you look through the hole in the carrier I can see two square cut gears. I held one wheel still and turned the other wheel and the center section clicks like its a ratchet type gear set. Any suggestions. Thanks
Old Oct 26, 2008 | 07:04 PM
mark a.'s Avatar
mark a.
Can you post a picture ?
66flareside
1978 - 1996 Big Bronco
Jan 12, 2014 02:52 PM
vafinest540
Dec 24, 2013 06:45 PM
djmichael24951
Oct 11, 2013 07:35 PM
illuminance72
1966 - 1977 Early Broncos
Apr 14, 2004 12:49 PM
