Sponsored by: Real Truck
Engine Oil Leak
Old Nov 5, 2008 | 05:02 AM
50jd60's Avatar
50jd60
It will be a reman engine. not a new one.......and they will use a lot of your old parts. Don't ask how I know.
05 F350 6.0
Old Nov 5, 2008 | 07:53 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Please excuse the hijack
LKWDF350 - welcome to the SoCal/Hawai'i chapter:
https://www.ford-trucks.com/forums/7...ml#post6728657
Old Nov 5, 2008 | 08:06 AM
senix's Avatar
senix
term is short block, heads exhaust all that stuff water pump and things transfer
Old Nov 5, 2008 | 10:53 AM
LKWDF350's Avatar
LKWDF350
50jd60 I figured they would use most of the old parts but the dealer said I was getting a new short block. I assume that means the engine block,crank,bearings and pistons.
Old Nov 5, 2008 | 11:26 AM
senix's Avatar
senix
And that is about it.
Old Nov 5, 2008 | 11:38 AM
50jd60's Avatar
50jd60
They put a new short block in mine, lasted 11,000 miles, destroyed itself, got a new reman engine, have had it for 13,000 miles, "OK"
Old Nov 5, 2008 | 11:51 AM
LKWDF350's Avatar
LKWDF350
Hey your making me nervous!!! On your first engine, what reason did you have to replace the engine?
Old Nov 5, 2008 | 12:03 PM
LKWDF350's Avatar
LKWDF350
Old Nov 5, 2008 | 12:30 PM
vettdvr's Avatar
vettdvr
Typically a "short" block does not have the heads. Basically it is the block and internal parts. This usually does not include heads unless you buy a (ready for this one!) Long Block. The long block will have in most cases have the heads and sheet metal.
Old Nov 15, 2008 | 11:54 AM
LKWDF350's Avatar
LKWDF350
Ok boys I got my truck back. Here is the scoop, fords mechanic used oil dye to find the leak. He found the leak at the Bed Plate. Removed engine and inspected Bed Plate Gasket Groove. Minimum spec is .167 in. for width and depth. The current measurement was .155 in.. Bed plate gasket groove is OUT of Spec. Replace short block assy., reinstalled engine assy. and cleaned charge air cooler tubes, road tested. They gave me 3 yrs or 100k mile warranty. I was out of town when my wife picked up the truck. She was a bit pissed off that they left the truck on empty!! But I'll fill it up this weekend and drive it of a while.
Old Nov 15, 2008 | 01:19 PM
vettdvr's Avatar
vettdvr
Well done. Looks like they really dug into the spec to find it was out of spec by .012". Most people just swap parts. My guess is they did a good job. I would call the fuel in the tank just part of the cost of repair because it sounds as if they knew the "right" fix and you got a new engine and 100000 warranty. Congrats.
Old Nov 15, 2008 | 01:56 PM
senix's Avatar
senix
sounds like a good deal, I would be happy knowing they found the true cause of it.
Old Nov 15, 2008 | 06:29 PM
  #28
SteveBricks
FTE Emeritus
Nice to get a fresh 100k warranty.
Glad to see you're back on the road.
Old Sep 2, 2010 | 11:01 AM
  #29
LKWDF350's Avatar
LKWDF350
I'm back!!! Guess what, the dealer found another oil leak! I 'll be dropping it off soon to see if they can find the leak and fix it. I'll keep you posted!
Old Sep 2, 2010 | 01:43 PM
  #30
senix's Avatar
senix
Tough break, hope it is an easy fix.
lauraj
Mar 16, 2013 06:38 PM
kyle j
Apr 11, 2011 06:32 AM
BLACK F 350
Feb 2, 2011 12:11 PM
Als03FX4
Jun 28, 2007 11:53 AM
jay9437
Jun 1, 2006 08:47 PM
