4x4 problem?
Old Oct 24, 2008 | 06:52 PM
Seasprite's Avatar
Seasprite
4x4 problem?
05 xlt 5.4 extended cab. Well today I thought I would lock in the 4 wheel drive while it was raining just to make sure every thing is working ok. Well flipped the switch and nothing happen the hubs didn't lock transfer case didn't shift. thought it was the vacuum solenoid but it wasn't that. I have the updated solenoid with the rain shield my old one was still good when I replaced it so just stuck it in the spare slot on the new bracket for a backup in case the new one goes bad. Anyway I shifted in to neutral to try 4 low then every thing starts to work again. I try to cycle my 4 wheel drive system once a month to make sure every thing is working and to keep it lubricated.
Could there be a problem with the digital transmission range sensor or should I be looking somewhere else? could even be a fluke not happen again.
Old Oct 24, 2008 | 07:12 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
on pavement right?
gotta ask the stupid question...but are you sure it didn't shift into 4x4?
there isn't always a thump or any other noise. and if you're on pavement, the noise/feeling could have easily been disgused.
I suggest you try doing it in dirt
or, did you jump straight to 4x4 lo without shifting to 4x4 hi first?
Old Oct 24, 2008 | 07:41 PM
Seasprite's Avatar
Seasprite
yes I was on very wet pavement.
positive it didn't shift mine always made noise when the hubs engage mainly just a click or clunk usually here the transfer case shift in to more so in 4low than 4high indicator lights didn't come on ether.
I don't drive it 4low on pavement just was just trying to get it to shift in any 4x4 gear I'll drive it in 4high on very wet pavement for couple of miles each month to check on things mainly use the 4x4 in snow & when hunting.
I did jump straight into 4low when 4high wasn't engageing every thing seems to be working as it should for the moment hope it stays that way. if it happens again just like to know ware to start looking.
Old Oct 24, 2008 | 07:54 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
no idea then...suggest you never use the 4x4 on pavement though...rain just isn't slippery enough
keep us posted if it does it again
Old Oct 27, 2008 | 07:45 PM
Seasprite's Avatar
Seasprite
Anybody have any ideas what would cause this ?
Old Oct 27, 2008 | 08:08 PM
bridge's Avatar
bridge
Sick 'n Tired
How fast were you going when you tried to put it into 4WD hi?
Old Oct 27, 2008 | 08:32 PM
Seasprite's Avatar
Seasprite
I was sitting in my driveway.
Old Oct 27, 2008 | 09:08 PM
bridge's Avatar
bridge
Sick 'n Tired
Oh...no clue then. Good luck.
Old Oct 28, 2008 | 01:26 AM
SuperCrew4U's Avatar
SuperCrew4U
The shift motor on my '05 supercrew went out with about 30,000 miles on it. When it went, it went. I couldn't get it to go into 4L or 4H so I don't know if that could be it or not.
Old Oct 28, 2008 | 02:04 PM
Fishin76's Avatar
Fishin76
I exercise my 4x4 every week, 4L and 4H. From what I have read, the T-case shift motor can corrode inside and freeze up. so, i keep everything moving by exercising it weekly. All it takes is shifting into 4H below 20 mph for a less than an 1/8 mile. Then stopping, shift to neutral, engage 4 low and drive 20-30 feet. Drive in reverse for 20-30 feet also to lubricate the transfer case throughly.
Thats all I do, 94k, still on the same t-case motor
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
da X-man
Sep 14, 2014 07:35 AM
69Cobra
Jan 18, 2011 06:44 PM
nalts
Sep 18, 2010 07:15 AM
63' f100
Jan 25, 2010 12:07 PM
