URGENT: Transfer case engaging on free will
I'm currently 600 miles from where I need to be on Thursday. The military doesn't like when you don't return from leave so this is a pressing matter.
Here's what's happening. My transfer case is engaging into 4hi on its own. It happened on the drive down here a couple times. Keeping it below 60 or so seemed to help. I took it to the Ford dealer to get fixed. They said it was caused by a leaking windshield corroding the gem and fuse box. They replaced those and said it was good. Didn't have an issue for about a week and then it happened again, but worse. In and out of 4hi every other second this time.
What else could be causing this issue? I picked up a replacement shift motor and solenoid. Should I try to replace those in the morning? As of now, I'm planning on removing the front driveshaft and driving back in 4hi.
I hate taking things to the shop for this exact reason. They didn't fix the problem. Dealer up there will be hearing from me. If I have my way, they will actually fix the problem and charge the dealer down here.
I'm currently in Orlando. Heading back to camp lejeune, nc.
I have warn hubs so I know they aren't engaging. When it goes into 4hi, the transfer case makes horrid grinding noises and clunks into range. I know it can't be good fit it. Worse case scenario, I'll take driveshaft out and drive back slow.
Quick update: Slowly but surely, I got the truck home. Didn't have much time to work on it since, but I did get the shift motor replaced. No improvement. I still have a grinding over 60mph. I'm thinking it is time for a full transfer case rebuild. Not sure what would break in order to cause it to engage on its own, but I figure if I'm going to tear it down, I might as well rebuild it and try to eliminate potential problems as I go. I cannot afford a new transfer case right now, so as I have funds available, I will start investigating/eliminating smaller things until I find the culprit.
The wiring harness on my 99 with esof will not latch fully , I at times have to get under the truck to press it on again to engage the 4x4.
At times I have had the indicator light come on and have to pull over and wiggle the harness and 're seat it , to get the light off.
If I have been in 4 low and the light goes off , the truck is stuck in low range.
My point is it might be in the connector for the shift motor , loose pin or harness connector.
boatcop1
1997-2006 Expedition & Navigator
08-08-2005 09:15 PM
