Center Cap Removal
Old Oct 28, 2008 | 01:55 PM
sammer4u's Avatar
sammer4u
Center Cap Removal
How do you remove your center caps without damaging the slot for removal or the wheel itself? The dealership obviously does not care, nor do they have the proper tool to remove them as mine are all chewed up and scracthed!
I used the stock lug wrench, with the rubber tip, but there has to be something else than getting that out each time?
Old Oct 28, 2008 | 02:11 PM
mercman86's Avatar
mercman86
i usually use a large screwdriver with some electrical tape wrapped several times around the tip to protect the finish, thats seems to work pretty good. i remember in high school we had a tool for removing and re-installing hub caps it had a soft tip and a rawhide hammer built into it for knocking them back on. havent seen any in the stores lately tho.
Old Oct 28, 2008 | 04:09 PM
wildcard30's Avatar
wildcard30
The lug nut tool that is stored with the jack has a rubber/foam collar on it. That's what I use. The rubber/foam saves the rim from getting chipped.
Old Oct 28, 2008 | 04:25 PM
Frd67cobra's Avatar
Frd67cobra
Try a vacuum line rubber cap stretched over the tip of a screwdriver,works good. You can get a pack of them in assorted sizes for a couple of bucks at an auto parts store.
Old Oct 28, 2008 | 04:27 PM
jager4006's Avatar
jager4006
as was said earlier i usually use a screwdriver with electrical tape over it, just take my time and try to to mess it up
Specularius
6.7L Power Stroke Diesel
24
Jun 24, 2021 05:15 AM
Ultraboy
Dec 16, 2013 07:58 PM
brsexton
Aug 13, 2009 09:08 AM
Meter Man
1983 - 2012 Ranger & B-Series
Oct 10, 2008 08:18 PM
Snyper
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 5, 2001 08:06 PM
