Never seen this before...
Old Mar 8, 2016 | 03:25 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Working on a 2000 7.3. It has what I thought was really bad turbo surge just rolling down the freeway with the cruise set at 70. It tunes out that the waistgate solenoid is opening and closing over and over and over. With the key on but engine off you can hear it opening and closing and it won't stop. Checked the MAP sensor and its showing 14.3 while the EBP sensor is showing 14.7. Was going to replace the MAP sensor anyways cause the plastic tab that keeps the plug locked onto it. None the less when I unplug the MAP sensor the waist gate solenoid keeps cycling. Do you think the waist gate solenoid is being told to do that and the issue is else where or its acting up its self? Was going to see what the voltage being fed to it is does any one know what I should be seeing with the key on engine off as far as volts go?
Old Mar 8, 2016 | 03:39 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
What does the wast gate actuator feel like it could have a bad diaphragm in it.
Old Mar 8, 2016 | 03:45 PM
Baatzy's Avatar
Baatzy
Is it your waste gate opening and closing or the EBPV? The stock waste gate has no computer control, so I am inclined to believe it is the EBPV. Look at the oil and air temps if you can, I believe one of these is used in the control scheme for the EBPV.
Baatzy
Old Mar 8, 2016 | 03:54 PM
weekendwarriorfsw32
Master of Strokes
No it is the Waitegate controller opening and closing for sure it is not the EBPV opening and closing that sounds like a jet. This is the solenoid mounted on the Spider that has the red and green lines running to it.
Old Mar 8, 2016 | 03:57 PM
weekendwarriorfsw32
Master of Strokes
It might but why is it opening and closing is what I can't get over. Its electric since the truck isn't running when its doing it and there is no boost running through it. Literally sounds like a solenoid opening and closing.
BTW thanks for again for waiting with me at RRE after leaving leaving Bens place waiting on Corey to uhhh "help" me
Old Mar 8, 2016 | 05:53 PM
carguy3j's Avatar
carguy3j
That green solenoid is controlled by the PCM, but all it does is to send a regulated amount of boost pressure (via the red plastic line) to the wastegate controller (the mechanical/spring diaphragm thing) to help force it amount quicker then spring pressure alone. Many people disconnect the red line, to prevent premature opening of the wastegate.
BUUTTTTT, you're saying the wastegate itself is cycling open/closed with the truck SHUT OFF?
That is physically impossible. With the truck shutoff, there is no airflow through the turbo, and certainly no boost pressure ( or more accurately, exhaust back pressure/drive pressure) to open the wastegate.
Unless your truck is possessed by the ghosts of Powerstrokes past, something isn't adding up.
Did you check to see if the rod from the wastegate controller is still hooked up to the wastegate arm on the turbo?
Old Mar 8, 2016 | 07:32 PM
Pikachu's Avatar
Pikachu
Pull the red line off the waste gate actuator and drive it. If the symptoms don't disappear, the waste gate control solenoid is eliminated as the cause.
Old Mar 8, 2016 | 07:43 PM
F350-6's Avatar
F350-6
Still trying to comprehend how this would be possible. Have you visually or by touch verified the wastegate rod is moving and actually opening and closing the flap?
Old Mar 8, 2016 | 08:25 PM
weekendwarriorfsw32
Master of Strokes
Im talking about the wastegate SOLENOID, not the physical waistegate moving. You can hear it clicking on and off on and off. Just to recap with the key on and engine OFF the waist gate its self is not moving but on the freeway going 70 the solenoid is still turning on and off which is causing the waist gate to open and close. Yes is you unplug to red line it goes away but I still wanted to get to the route of why its doing that.
Old Mar 8, 2016 | 08:38 PM
Pikachu's Avatar
Pikachu
When the waste gate control solenoid is powered (active) it is sending less pressure to the waste gate actuator. It's normal for it to be active KOEO and under low boost conditions. It is controlled by a duty cycle percentage, like the IPR is. The lower the duty cycle, the less pressure it's sending to the actuator.
Old Mar 8, 2016 | 08:59 PM
weekendwarriorfsw32
Master of Strokes
This is the only truck I have ever seen that clicks it on and off constantly while the key is on with he truck running. My 7.3 does not do that
Old Mar 9, 2016 | 08:38 AM
tjmike's Avatar
tjmike
Maybe you can just hear this one and not others.
Can you swap with another for a test?
Old Mar 14, 2016 | 12:29 AM
retiredsparky's Avatar
retiredsparky
How old are your batteries? A battery that has internal problems will still often start and run, but can cause strange electrical events.
Also loose or corroded grounds.
I have had two vehicles with battery problems -when I replaced the batteries, problems went away.
Shiro
Apr 6, 2014 11:02 AM
2006powerstroke90
Feb 8, 2012 01:25 PM
kx450frider617
36
Nov 23, 2010 09:53 PM
gordoman
Apr 19, 2010 05:52 AM
bublitz3
16
Aug 3, 2009 04:22 PM
