Limited Slip
Old Apr 9, 2009 | 08:12 PM
BadDogPSD's Avatar
BadDogPSD
Originally Posted by c00nhunterjoe
you will be amazed at the size and weight difference
Okay guys, finally got the 10.5 LS unit! Now I need to order some 4.10 gears. Which install kit should I get? Looks like there are two, a minor & a major? Any other tips/tricks for this swap?
Old Apr 10, 2009 | 06:30 AM
Cuda_jim's Avatar
Cuda_jim
Be sure to keep track of the carrier shims when you remove the old carrier from your housing. They will go in with the new carrier to set the back lash.
I would get the complete kit since you are changing the ring and pinion too. The major kit should come with all new bearings, crush sleeve, shims ect. But even the major kit may not contain a wide enough assortment of shims to set the pinion depth correctly. This usually isn't a DIY'er task unless you have the specialized tools, extra shims and knowledge needed. If you miss the pinion depth a new crush sleeve will be needed.
That being said, there are many guys here that can walk you through the process but it may take a little extra time because you will need to make things on the fly. ie. grind the old bearing so they slip on and off the pinion gear. Figure out a way to measure the pinion depth within thousandths of an inch ect.
I've changed a lot of ring and pinions and found it much faster and less hassle to have it done at a R&P shop. The guy I use charges $20-30 labor + parts for the swap. He can get the bearings, shims and crush sleeves cheaper than I can so it's a win, win situation. It's a bolt in job from there.
scottm1
Jun 9, 2013 01:05 PM
gmetime24
May 21, 2011 04:22 PM
Sparky04SD
Mar 16, 2011 12:14 AM
txflyyaker
2004 - 2008 F150
18
May 18, 2006 11:52 PM
jasonlasvegas
Sep 13, 2004 05:31 PM
