Air intakes
Old Oct 24, 2008 | 11:24 AM
  #31
F250_'s Avatar
F250_
Hey, even if you order from Fleetfilter, their shipping is typically only about 2 days, 3 days max, and you can sometimes save as much as $20 by ordering from them instead of getting it at your local NAPA store. Also, if you order two filters from Fleetfilter, the S&H doesn't change, so you end up getting a better price/filter, which is the way I always order mine.
Here's the link to them.
http://www.fleetfilter.com/ just enter 46637 into the Wix/napa number window and click "Find your filters".
Old Oct 24, 2008 | 11:29 AM
  #32
WH90's Avatar
WH90
Oil filters, biodiesel filters, air filters, and fuel filters from FleetFilter.com just enter 46637 into the Wix/napa number window and click "Find your filters".
Appreciate it man, thanks everyone for being so kind
Old Oct 24, 2008 | 11:38 AM
  #33
F250_'s Avatar
F250_
Originally Posted by WH90
... thanks everyone for being so kind
That's the way we've all been treated when we first came on board here in FTE, and we like to welcome and care for new family members as they (like you) show up.
Old Oct 26, 2008 | 12:38 PM
  #34
John7894's Avatar
John7894
Originally Posted by superduty4x4
But it's a noisy bastage unless you build a cold air box, but even at that you're still WAY less than even a used AFE Stage II setup.
That's why I just re-installed my stock box. Was tired of the sucking sound. Nice and quiet now and no change in performance.
I'm going to pick up an AIS soon though.
Old Oct 26, 2008 | 03:13 PM
  #35
Izzy351's Avatar
Izzy351
The stock box can leak like a banshee though. I personally like the sounds, but to each his own. I recommend you get that stock box outta there sooner and not later though. We just worked on a truck with a really dusty intake because of that chitty box...
EDIT: With no tunes, you probably won't notice a difference, but with the 10psi increase in boost over stock, I know that box is a serious restriction.
Old Oct 26, 2008 | 04:46 PM
  #36
cmpd1781's Avatar
cmpd1781
What does the 6637 give you guys (hp/tq) over the stock box?
Old Oct 26, 2008 | 06:39 PM
  #37
Izzy351's Avatar
Izzy351
I don't know, but I'm sure it will cause some extra black smoke, which = power loss. I tossed mine in the nearest dumpster when I put on the 6637. You'd have to do back-to-back dyno runs to find out. It would be interesting to see. I'd like to see vacuum numbers in the intake as well.
However, either way, the stock box is trash -- it needs to go. Anything but a K&N...
Old Oct 26, 2008 | 08:22 PM
  #38
cmpd1781's Avatar
cmpd1781
I'm looking at the AFE.....SUPPOSEDLY.......50hp and 115tq......But that's just supposedly.....
Old Oct 26, 2008 | 08:24 PM
  #39
Izzy351's Avatar
Izzy351
Yeah...........
Old Oct 28, 2008 | 01:50 PM
  #40
snakyjake's Avatar
snakyjake
As for the noise on an open box air intake, I didn't notice extra noise. I hear a lot more from road noise.
Old Oct 28, 2008 | 02:00 PM
  #41
snakyjake's Avatar
snakyjake
The install is straight forward:
1. Remove stock air filter box. Unsnap, unscrew...done.
2. Connect 6637 (or similar) filter to intake hose.
a. Use a 4"x4" exhaust pipe (you can typically get it free at a muffler shop). PVC is okay too. You just need a way to connect the filter to the hose. Don't make it more complicated than what it is.
b. Attach filter to exhaust pipe using 4" clamp.
It's a very easy and economical intake system.
I would consider the AIS if you frequent dusty conditions.
I would consider S&B if you want a washable filter to save on filter costs (some people drive a lot of miles). But I don't mind paying <$30 per year for a new 6637 type filter. I don't like worrying about proper oiling of a S&B type filter.
The 6637 is difficult to beat in terms of both performance, efficiency, and cost. Even when cost is not an issue, I still chose 6637.
Old Oct 28, 2008 | 03:32 PM
  #42
PwerStroke99's Avatar
PwerStroke99
u WILL NOT get 50 hp from the AFE
fancyvern
Sep 26, 2012 12:37 AM
MountainHawk
2004 - 2008 F150
Dec 31, 2011 01:49 PM
offroad17
Air Intakes, Air Filters & Ram Air
Nov 7, 2008 12:16 PM
chris1066
15
Jun 1, 2008 12:51 AM
Ginzu
Feb 15, 2008 06:50 PM
