My late ’99 F-350 PSD with 227,000 miles on it sputters when you are driving it at speed and if you are not moving like at a stop light instead of just sputtering it shuts off like you turn the key off. I thought it was the fuel filter so I changed that and thought it fixed it but it kept doing it the next day. It is weird some days it will not do it all day and some days it will do it a dozen times or more. Not only is it annoying but I do not want to burn out the starter, or cause further damage. Also on the days it decides to run good you would never know that anything was wrong with it, it runs completely normal. I hate problems like this!
it is a sensor located on the passenger side just above the crank shaft pulley on the front of the engine....it is very simple to change you need a 10mm socked a short extension and a flat head screw driver to pop the old one out.
To replace pull the plug off, take out the bolt pry the old sensor out and put the new one in put the bolt in and put the plug back on making sure not to wrinkle the moisture guard...takes about 10 minutes
I am with you.......but the dang work computer doesn't have my links on it.........
interesting question slightly OT, I cannot access that link it says "forbidden 403" y'all think this is just cause Im on a MAC? so far that has been the old site other than AKO links that I have problems with on this computer.
I have no idea. You can try to access his main page
guzzle.rbmicro dot com
The CPS link is under the repair and maintenance section. It's a handy site to have bookmarked. I typed in the address (just use a . instead of the spelled out dot) in case the problem is with the link.
Nope.."403 FORBIDDEN
Hello 84.57.86.110
You do not have permission to access this site.
This is most likely due to abuse by your IP address or because you are a bot that is known to cause abuse. If you believe you should be able to access this site please contact the administrator"
... the rest is a black screen, Ive tried from both windows based pc's and different OS on this MAC.. all get the same message.. but that is not the correct IP for any of the equipment on this network Will try from a different network tomorrow, although I did make a note of the website.
Thanks guys that part is a recall and I am bringing the truck in to get it fixed for FREE!!!
You guys saved me alot of scratching my head or getting screwed at a dealership.
Hello 84.57.86.110
Your IP address is coming from Germany and unfortunately, I had blocked the entire 84.x.x.x subnet due to spam bots and hackers from this subnet trying to spam the forum. I have lifted this subnet so it should work now but if the spammers hit again, I may have to lock it up again..... Sorry.
Thank you.. right now I'm reading your site like crazy, bookmarking, you can re-block this subnet by the time you get up, as I now have it in my folder for later. Im not actually working on my truck, she's parked in CO.
