Just wondering if there is a way to hook the ebpv brake to turn on by a toggle switch and then run it through the tps so when depressed truck runs normal then released to engage the brake just like my big rig was.
what and where is the IVS havent seen that one on here yet? Also does anyone have this done and also a diagram or pic. Thank you. I just think that it would be cool that when you let off pedal you get exhaust brake.
the ivs is on the throttle pedal assemble, you will see a button that the pedal rests against in the "no throttle" position. just wire that into a relay to supply power to your ebp valve and you are set.
anytime!! its always my pleasure. if you wire it up to the ivs switch dont forget to add a manual override on-off switch. otherwise the valve would activate anytime the truck idles......
