Offroad & 4x4
spring bushing replacement
Old Jun 14, 1999 | 12:49 AM
whd507's Avatar
whd507
howdy. I've got a 1997 F-250HD (old body style) powerstroke 4x4. I would like to replace the rubber spring bushings with greasable polyurethane bushings. My problem is finding them for the F-250. I'm new to 4x4s and haven't made many connections yet. thanx
Old Jun 14, 1999 | 09:24 AM
Chuck P.'s Avatar
Chuck P.
Hi whd507, You didn't spec if you want them for the front or rear springs. So, here it goes, the most known company is "Energy Suspension" out of Ca., at <a href="http://www.energysuspension.com">http://www.energysuspension.com</a>. These folks should be able to hook you up. However, when used in the rear, they tend to make the suspension stiffer, great for handling and hauling, not so good for fleoffroad), the local spring shop here recomended staying with the rubber in the rear due to the fact they believe the poly contributes to spring failure rate increase. They have recommended them in the front due to the above stated reasons. Good luck, Chuck
Old Jun 26, 1999 | 05:16 PM
1tom's Avatar
1tom
Old Sep 20, 2004 | 08:57 PM
fishmanndotcom's Avatar
fishmanndotcom
daystar and performance accessories also sells them...not to mention any of the lift kit companies will sell individual parts including bushings
-cutts-
Old Sep 20, 2004 | 09:58 PM
ivanribic's Avatar
ivanribic
Good to know. I need a set for my front lift springs . . . they didn't come with bushings. Are all F250 spring bushings going to be the same size?
Old Sep 20, 2004 | 10:05 PM
proeliator's Avatar
proeliator
Pm whd507, he's probably an expert by now.
Old Sep 21, 2004 | 10:21 PM
JeremyH's Avatar
JeremyH
HaHa........yep.......quite an old thread.
F-250 WARHORSE
Jan 7, 2017 08:34 AM
green_95
May 31, 2016 08:46 AM
KsHighboy
Mar 27, 2016 08:59 AM
Trevor1
Oct 13, 2006 06:59 PM
