Leaf spring bushings.
Old Mar 26, 2016 | 10:22 AM
KsHighboy's Avatar
KsHighboy
Need to replace the rear leaf spring bushings in my 67 F250 4x4. NPD says these are the ones but I'm always worried ordering parts for these old trucks on line won't fit and have to send back. Think NPD's applications are correct?
npdlink.com/store/products/bushing_rear_spring_or_shackle_c7tz_5781_c-134264-50000.html
Old Mar 26, 2016 | 05:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TZ-5781-C .. Rear Spring Bushing / 1 9/32" O.D. x 5/8" I.D. x 2 3/4" long / Obsolete
Applications: 1967/77 F250 4WD (High Boys).
Old Mar 26, 2016 | 07:43 PM
KsHighboy's Avatar
KsHighboy
Thank you! Looks right!
Old Mar 27, 2016 | 08:49 AM
orich's Avatar
orich
Poly bushing way easier to install compared to OEM bushing. Plus you'll bleed less and won't run out of curse words..
A press makes the job much easier but if no press then a few extra tools needed.
A sawsall, hand drill & heavy duty metal deep circle hole saw cutter to get the rubber out & a few small wire wheels to clean the rusty bushing bores.
A big Fxxking Hammer. I made up a bolt puller & a few big washer to install the OEM bushing the first time.
The second time learned my lesson an got the black poly bushing.
The cleaner you get them the easier the bushing will go in. And you still may need to have them pressed in if you can't manage to get them all the way in.
Or pay a shop to do the nasty dirty work.
Get the black ones as they don't squeak like the red ones.
If you notice any body sagging check that it's not from weak springs as I've had to replace all four with later heavy duty one's as I had a c/o camper on back for many yrs.
New spring with new bushings save a lot of extra work plus better ride.
Orich
Old Mar 27, 2016 | 08:59 AM
KsHighboy's Avatar
KsHighboy
Poly would be easier but I had them in the front years ago and the ride was horrible and squeaky. I have access to a press.
desertwest
Feb 3, 2016 12:07 PM
greatbargins10
Apr 15, 2012 06:39 PM
Marky48170
1983 - 2012 Ranger & B-Series
May 8, 2011 07:18 PM
marshpoprock
Feb 22, 2009 10:03 AM
jgrim23
Jun 13, 2006 08:11 PM
