trans. ID and compatability
Old Oct 20, 2008 | 11:38 PM
21411's Avatar
21411
Question trans. ID and compatability
can anyone identify this trans code. i believe its
T 18-IE
WO DIV.
it is a 4 speed, 1 st is granny and rev. is right and up.
there is no reason to believe that it originaly came in the truck.
then is this trans strong enough for the 460. the local auto shop instructor did not see any problem except that the bell housing will have to be replaced.
thanks for looking
Old Oct 20, 2008 | 11:42 PM
camperspecial65's Avatar
camperspecial65
If thats whats cast in the case or on its tag on the side then it is indeed a T18...as for putting it behind a 460...I am not sure, but Im sure others will chime in.
- cs65
Old Oct 20, 2008 | 11:56 PM
21411's Avatar
21411
that is cast on the left side of the case.
Old Oct 21, 2008 | 12:08 AM
85e150's Avatar
85e150
Not a problem behind a 460, if that's the trans you want.
Old Oct 21, 2008 | 12:43 AM
21411's Avatar
21411
really just wondering if that would be another expence in going with the big block, but if it can handle the torque then its not a problem. thanks
Old Oct 21, 2008 | 04:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
T 18-IE / WO DIV. It is a 4 speed, 1 st is granny and rev. is right and up.
T18-1E is the transmission case ID code, not the transmission code.
The transmission ID tag is (was-prolly missing by now) bolted to the back side of the case, right side upper.
The (original) TRANS code is on the Warranty Plate, located on the left door face below the latch.
Your profile says you have a 1964 F100. 1964's didn't use Warner T18's, they used Warner T98's.
The case used with a T18 is not the same as a T98, so if you have a 1964 F100 w/a T-18, the trans was swapped at some time.
1965 was the first year for T-18's in F Series trucks.
1983 was the first year a 460 was available with a manual transmission. Transmissions used: Warner T-18 & T-19C
Old Oct 21, 2008 | 09:25 AM
21411's Avatar
21411
so it must be a good transmission if they used it for so long.
thanks
filthy6
Dec 22, 2014 06:51 AM
filthy6
Dec 12, 2014 02:58 PM
68fish
Nov 9, 2014 12:20 AM
cherrybomb37
Jul 28, 2014 08:19 AM
newguy399
Dec 10, 2013 10:59 PM
