I am looking at buying an ats 093 kit from a 94 idi. Are these kits tranny specific like the older banks kits? Its almost complete, has everything except the airbox, but I suppose one can be easily made. The kit is on an automatic and mines a 5 sp.
If I remember right, the turbo kit was the same for auto or manual tranny.
The auto tranny kit has a different dipstick and tube to relocate it away from the downpipe.
The trubo off a stock Ford turbo engine is not really an ATS 093 kit.
For re engineered the turbo outlet and downpipe to a much smaller one than ATS uses.
Ok, so it will bolt up just fine. Ill upgrade the turbo at a later time to the 3 in downpipe.
After looking at the banks kit, it will fit my truck, but will require a body lift or a hack job. Plus the exhaust is a lot easier to install on the newer ats kit then on the older banks.
