I have a 94 F-150 Ext Cab 2WD, 4.9L, 4 speed W/OD, 4" Cepek lift, 2" body lift and 3.55 gears. I want to get bigger tires (35X12.5X15) and i am not sure if they will fit, also I am not sure what gear ratio that I need to make it drivable. I am not planning on doing any wheeling, just basiclly for looks. Any help/advice would be appreicated.
Kevin,
The 35s will definitely fit with 6" of lift,(almost anything will fit with 6").You will probably want to run at least 4.10:1 gears,the 35s will sap a lot of your power as well as lower your RPMs.
Jeff
I always wondered what a 2wd would look like with a lift installed? Have you got some pic's on it?
I agree that the 4.10 gears would be a minumum for 35's,even if just for looks.You said you've got a 4spd w/OD? Is it OD in 4th or actually a 5spd? Do you have a low {granny}1st gear? My 88 F150 300 4spd w/low 1 will pull a house on wheels if necessary.Don't know the gear ratio but never wondered because it revs well in all gears,even with 31's.How does that lift look????
Phillip
actually it was the very last thread on the very last page..
i thought it was usefully, you know being a good role model for the newbs, so they know searching is ok...
