Coil ground?
Old Oct 19, 2008 | 08:38 PM
John_deere_kid's Avatar
John_deere_kid
Coil ground?
I'm trying to install a tach in my truck (see sig), and it says for distributor equipped vehicles, to hook the green wire to the negative (ground side) of the coil. Where is it? and if someone has a picture, that would be great cause even with my test light i wasn't havin any luck.
Old Oct 19, 2008 | 08:53 PM
95F350XL's Avatar
95F350XL
if you unplug the coil its labled + and - on the inside, but it is the left wire if your looking at the coil from the front of the truck.
You see where the tap is installed thats the neg side as thats my tach wire.
Old Oct 20, 2008 | 04:45 AM
ymeski56's Avatar
ymeski56
Der Postmeister
Check the wiring diagram for your dash. Tach wiring is ialready included in one of the 2 harness connectors that plug into the dash. Or I went to psalvage yard andand pulled rhe display out of a truck that had a tach & trip odometer plugs in and needs no new wiring. Have to use same type speedo type cable or electronic also get oil sender as its matched to the gauge $35 bucks for both.Also it can be out of multi trucks & years. I took mineout of a 91 lariat for my 87'f-150 but any 87' &-91' ranger or bronco also fair game.
Old Oct 20, 2008 | 09:20 AM
TexasGuy001's Avatar
TexasGuy001
You could just get an instrument cluster with a tach. Its a plug and play swap. Just make sure you get a cluster from a 92 or 93. The other years won't work correctly.
Old Oct 20, 2008 | 04:53 PM
John_deere_kid
but wont the mileage also be off then?
F350xl,
couple questions:
Is that red clip just out of your coil for a tach?
What is the msd coil you have? I have thought about upgrading my coil and am looking at my options.
Old Oct 20, 2008 | 05:37 PM
quicklook2's Avatar
quicklook2
you remove the speedo/odo from your old cluster so mileage is the same.
go to articles/specs at top of page and you will find an article on how to do the swap.
Old Oct 20, 2008 | 06:31 PM
95F350XL's Avatar
95F350XL
I have a MSD 6a box and got the coil with it, the red connector is a tap that taps into the wire, it has since been rewired but thats how it would go. I like the tach on the wheel better then the cluster, too much work for me.
Here is a pic of the tach
Old Oct 20, 2008 | 06:34 PM
EPNCSU2006's Avatar
EPNCSU2006
Personally, I hate those quick taps and recommend avoiding using them unless it is the only thing that will get you home after a break-down.
Old Oct 20, 2008 | 06:45 PM
95F350XL's Avatar
95F350XL
I have since sodered a new connector in, that was to make sure it worked and for mock up.
Old Oct 20, 2008 | 08:19 PM
John_deere_kid
Is that the super tach II that you can get at auto zone? thats what i got, except white.
How was the install of the MSD system?
Old Oct 20, 2008 | 10:35 PM
95F350XL's Avatar
95F350XL
Yea I think it was the super tach 2, MSD was cake to install, 1 to +, 1 to -, 1 to + of factory coil wire, and 1 to neg of factory coil wire, then you have a pos and neg from the box to the coil.
Steves55
Apr 13, 2017 10:48 PM
3twinridges
20
Aug 19, 2016 06:49 PM
Cougar54
Sep 20, 2015 09:30 PM
mikecomar
Jul 21, 2015 07:07 PM
charles jones
Jan 7, 2006 07:59 PM
