What did I miss???
Old Oct 18, 2008 | 08:08 PM
Kongslibakken's Avatar
Kongslibakken
What did I miss???
I have a 96 Explorer with a 4.0 Mfg 1/96 I bought it from a fella who Hydro locked the Motor driving through a puddle. So we picked up a Wrecking yard motor from a rolled over 96 Explorer Mfg 6/96 we spent today throwing it in. The differences were Auto Trans in the donor 5 speed in mine I used the wiring Harness out of our 96 Labeled everything and we were very careful about the switch. Everything hooked back up there are no stray wires or connecters. We pulled the front line off of the fuel rail in the front and my son turned the key on and fuel shot up bout 6 inches oops! Where do you check the fuel pressure and with what type of gauge. We checked our spark and it is fine. Is there anything else I can check. Will the computer recognize the new motor or does it need to be reset. Any help would be great.
Old Oct 18, 2008 | 10:53 PM
aquanaut20's Avatar
aquanaut20
You need to tell us what it is doing, or not. Otherwise it is a guessing game.
Do you have any current codes, initiated by the new install?
Old Oct 18, 2008 | 11:03 PM
Kongslibakken
Sorry the engine cranks over fine it just won't fire. Plenty of fuel good spark it just won't fire.No codes as of right now.
Old Oct 18, 2008 | 11:10 PM
MCDT's Avatar
MCDT
If he hydolocked the motor I would assume the fuel tank got its share of water. Did you drop the tank flush everything and replace the filter? This might just be a case of really crap gas.
Old Oct 19, 2008 | 02:48 PM
Kongslibakken
Well we pulled the gas Tank and found some rather brown gas full tank of course. M/T the tank and cleaned it out now we have fresh gas we cycled the pump several times to clear the lines and we still have no fire in the hole.
Old Oct 19, 2008 | 04:09 PM
aquanaut20's Avatar
aquanaut20
you may have to remove the injectors and back flush them
Old Oct 19, 2008 | 05:15 PM
Kongslibakken
Whats the best way to backflush them with air or??
Old Oct 19, 2008 | 05:24 PM
aquanaut20's Avatar
aquanaut20
Check if you have a professional injector shop close b y, last time I did some, cost me 12.00ea.
But on the other hand don't you have a set in the old engine?? swap them out!
Old Oct 19, 2008 | 05:32 PM
Kongslibakken
In process we hooked up to the air fitting on the injector rail and blew back to the tank. We are going to change injecters now I'll let you know Thanks
Old Oct 19, 2008 | 07:30 PM
Kongslibakken
Changed the injectors and it fired right up we are now pulling a p0113 code it runs rough and backfires.
Old Oct 20, 2008 | 04:33 PM
MCDT's Avatar
MCDT
p0113...IAT Sensor 1 Circuit High Input. I don't know what it means but just incase you needed to know what the code was.
Old Oct 20, 2008 | 07:53 PM
lugnut's Avatar
lugnut
IAT = Intake Air Temperature sensor- Did you plug it in? I don't know where it is located on that engine- possibly on the intake plenum.
mike
