Hello from Florida
Old Oct 18, 2008 | 08:01 PM
Herleman's Avatar
Herleman
Hello from Florida
New here.
I just came home with a 2008 Ranger XLT short bed 2.3, auto.
Its pretty much a basic truck (I've added an Undercover lid and a Class III hitch).
It'll primarily be used to run around town after groceries and nuts and bolts from Home Depot.
Its other job will be to pull my bike in its little trailer (BMW F800 and a small enclosed utility trailer, 5X8, 700 lbs).
I traded a 2005 Chevy Silverado V6, 5spd for the Ranger. It had way too many issues with steering, catalytic converters, and transmission bearings. It had a very short life with me (31K miles) and averaged between 13 and 16 mpg around town. I had to make a change.
The little Ranger got 22.2 mpg from the first tank, and its running on the second tank right now (423 miles).
I'm a member of a couple of the bike forums and found them to be very useful.
I hope to get as much out of this forum as I have from them.
My only realy question at this point is whether the little truck is up tp pulling the trailer. Its about 900 lbs fully loaded.
Anyone with experience pulling trailers out there???
Any other advice for a newbie???
Old Oct 18, 2008 | 08:03 PM
michigan66's Avatar
michigan66
Welcome to FTE. It is a very useful site. At the moment, my only advice is "Enjoy your Ranger."
Old Oct 19, 2008 | 07:03 AM
97ranger xlt's Avatar
97ranger xlt
you will have no problem at all pulling 900lbs. i have pulled easily a 2000lb boat and trailer combo right off the bumper hitch.
enjoy your Ranger! you will never run out of things you can do with it.
Old Oct 19, 2008 | 01:21 PM
sfcwoodret's Avatar
sfcwoodret
It will pull that and more.
Old Oct 20, 2008 | 07:59 AM
Rockledge's Avatar
Rockledge
Welcome! With that class III hitch, you won't have any problems hauling that trailer around.
Good luck with the new Ranger.
Old Oct 21, 2008 | 04:43 AM
wendell borror's Avatar
wendell borror
Welcome aboard, if you do have problems pulling the BMW. You can allways unload it and use it to pull the ranger ha ha. You'll be fine!!!!!
Old Oct 21, 2008 | 08:14 AM
BSmitty's Avatar
BSmitty
Welcome, glad you found this site. You'll find this site very useful, no doubt. Unless the tires are flat, you should pull your trailer effortlessly, those Duratec 2.3l's are pretty potent. Keep the tranmission serviced and it won't complain either, they're fairly durable. What year is your BMW?
