99 2.5L Crankshaft Pulley Removal
In the process of replacing the timing belt and I need to remove the crankshaft pulley. I don't have an impact wrench but I do have a large breaking bar. What methods (or tools) will keep the crankshaft from turning while trying to loosen the bolt. I don't want to put a pipe wrench on the balancer.
Thanks!
Thanks!
Now I just need to get the pulley/balancer off. Off to Autozone for a pulley puller.
Do most of you change the timing belt tensioner while you're in there? If so how do you change the tensioner spring?
Thanks.
Aaron-71
07-16-2015 02:19 PM
RIKIL
03-05-2010 03:57 PM
Dannym
12-20-2004 10:30 AM
