i did a KOEO test n got code 452 about the speed sensor, then i did a KOER test n got the code 632 Overdrive transmission cancel switch/no action during self engine run test,
can u tell me where the switch is and how i might fix it,
Thanks.
Your O/D switch is at the end of your shift lever ****. You cycle the switch when starting the KOEO(R) self test. That is the code you will get if you don't do this.
Only once. It is done right after receiving engine ID code - After the engine ID code:
Depress and release the brake pedal,
Turn the steering wheel 1/2 turn and release it.
If the vehicle is equipped with an E4OD transmission cycle the Overdrive Cancel Switch.
After dynamic response code 10 - Within 15 seconds of receiving a code 10, momentarily place throttle in wide open position, then quickly allow throttle to return to idle position, - do this one fast.
Hope this helps.
