another e4od code question
Old Oct 18, 2008 | 03:53 PM
Cdy1's Avatar
Cdy1
i did a KOEO test n got code 452 about the speed sensor, then i did a KOER test n got the code 632 Overdrive transmission cancel switch/no action during self engine run test,
can u tell me where the switch is and how i might fix it,
Thanks.
Old Oct 18, 2008 | 04:13 PM
mike93's Avatar
mike93
Your O/D switch is at the end of your shift lever ****. You cycle the switch when starting the KOEO(R) self test. That is the code you will get if you don't do this.
Old Oct 18, 2008 | 04:20 PM
Cdy1's Avatar
Cdy1
should i turn it off n on once or a few times?
Old Oct 19, 2008 | 04:19 PM
mike93's Avatar
mike93
Only once. It is done right after receiving engine ID code - After the engine ID code:
Depress and release the brake pedal,
Turn the steering wheel 1/2 turn and release it.
If the vehicle is equipped with an E4OD transmission cycle the Overdrive Cancel Switch.
After dynamic response code 10 - Within 15 seconds of receiving a code 10, momentarily place throttle in wide open position, then quickly allow throttle to return to idle position, - do this one fast.
Hope this helps.
Farmboypowerstroke
Oct 29, 2011 05:05 PM
fkaster01
Apr 3, 2009 06:24 PM
Pastmaster
Jan 2, 2003 05:53 PM
jonw440
1978 - 1996 Big Bronco
Feb 16, 2002 02:58 PM
