engine removal tips
Old Oct 18, 2008 | 10:41 AM
ponch37300's Avatar
ponch37300
engine removal tips
i'm planning on pulling my engine this winter and looking for any tips or write ups of things to look for a do to make it easier. Doing it cause i have some oil leaks for a while that will be easier to fix and mainly doing for fun/experience. Just wondering if there is any write ups on this or things i need to know before diving into this project. Thanks
Old Oct 18, 2008 | 11:00 AM
SolidGround's Avatar
SolidGround
Most of the guys around here tear down the whole front of the truck to remove the engine. I don't agree with that and have never done it (for engine removal). I think (depending on your shop access) it's easier to lift the cab. But like I said, depending on shop access, this may not be the route for you.
What kinda oil leaks?
Old Oct 18, 2008 | 03:52 PM
ponch37300's Avatar
ponch37300
I don't have the space to do a cab off and from looking at pictures it looks like taking the front off is prettty easy. What advantage do you gain by taking the cab off verse the front end? I have a turbo leak, think it is the EBPV actuator on the pedistal. And also a leak from the oil dip stick going into the pan. I have read about the kit from international to fix that but also read if you don't do it perfect you are screwed. Just thought more or less i would do it for fun and fix everything while it is out and easy to get at. I've pulled probably 10 engines out of cars and trucks, including my 5.4 f150 but never a diesel. Just thought maybe someone has done a write up on pulling the engine when they did theirs. I have the sevice manual on dvd and will look at that this weekend to see what i can learn from that but thought maybe someone has some real world experience they can share that means more than a book.
Old Oct 18, 2008 | 04:07 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Make sure you have alot of place to put stuff you take off!
Old Oct 18, 2008 | 04:20 PM
ron's power stroke's Avatar
ron's power stroke
pull turbo, front clip, bumper (gains you a few extra inches), upper core support, radiator, <ACRONYM title=Intercooler>IC</ACRONYM>, rotate the <ACRONYM title="Air Conditioning">AC</ACRONYM> condenser out of your way, toward the passenger side (or get it discharged & remove it completely)...
trans bolts, <ACRONYM title="Torque Converter">TC</ACRONYM> bolts, motor mounts (from cross member), disconnect factory fuel lines (QD fittings on drivers side of engine cross member, PITA), belt, fan, alternator & <ACRONYM title="Air Conditioning">AC</ACRONYM> accessory brackets (let the PS pump hang out in the eng comp't, drivers side)...
disconnect batteries, starter (let it hang from a coat hanger), eng wiring harness, grounds (front both sides & rear PS head)...might want to use a tranny jack to support the trans as you wiggle the engine forward & up...
ill be doing this real soon my self..
Old Oct 18, 2008 | 04:22 PM
PowerstrokeJunkie
Dont let the starter hang, and also remove the batteries.
Old Oct 18, 2008 | 04:27 PM
ron's power stroke
driver side battery only cause you want to take the air box out..why not hang the starter?? less wires to mess with..
Old Oct 18, 2008 | 04:40 PM
danskool's Avatar
danskool
Go Bills !
https://www.ford-trucks.com/forums/6...werstroke.html
Good link on Post #9 from Mike (ford79)
Old Oct 18, 2008 | 04:57 PM
SuperDoodie's Avatar
SuperDoodie
I pulled the front off when I did mine (both times).. Its not that bad. Had my engine out in 3 1/2 hrs..
Old Oct 18, 2008 | 05:14 PM
ponch37300's Avatar
ponch37300
Thanks for all the tips and links. will a normal 2 ton hoist work? i have a load leveler to. Does it come straight out or do you have to twist it and angle it just right to get it out? Thanks again
Old Oct 18, 2008 | 05:37 PM
SuperDoodie
Comes right out the front
danskool's Avatar
danskool
Go Bills !
Dang, That is a wet dream shop. Nice and clean. I would tackle anything with a garage like that.
Old Oct 18, 2008 | 05:43 PM
ponch37300's Avatar
ponch37300
Ya i was going to comment on how nice it would be to have a shop like that to work in! Thanks again for all your advice guys.
F-WhiteThunder
1983 - 2012 Ranger & B-Series
Jun 9, 2023 09:05 AM
RL250
13
Sep 24, 2014 11:43 AM
BLADE35
23
Jun 29, 2014 12:29 PM
merace19
Dec 13, 2009 09:53 AM
