Hey guys, Im getting ready to go out to the shop and do some tinkering,I was wondering if someone could please give me the correct torque specs for ...1)Valve body bolts..2)Injector hold down bolts and 3)Rocker arm hold down bolts. When I ordered my valve body from Brian(like back in March) I didnt order it for the DP Tuner(also got back in March),so I spoke with Cale the other day and he sent me the correct Transgo plate,Im also torqueing(spelling)the injectors and rocker arms, and also replacing my EBPV solinoid.Im thinkin its gonna be a good night for some wrenching(nice and cool and sippin homemade hot chocolate)Rambling.......I know...,if someone could please give me the torque specs I would really appreciate it.
Thx...Schlepprock
Torque Specifications Description Nm lb-ft lb-in
Center support fluid feed bolt (two rear) 16 12 —
Cooler bypass valve (CBV) fitting to case (front) 30 22 —
Cooler bypass valve (CBV) fitting to case (rear) 37 27 —
Cooler line fitting to CBV (front and rear) 27 20 —
Connector — radiator nipple 23-31 17-23 —
Connector, radiator-to-tube 24-30 18-22 —
Connectors, radiator-to-tube 27-31 20-23 —
Auxiliary cooler tube 11-14 8-10 —
Auxiliary cooler tube 22-30 16-22 —
Control assembly to pump 24-31 18-23 —
Torque converter drain plug 24-27 18-20 —
Flexplate inspection cover (7.3L diesel) 20 15 —
Flexplate inspection cover to case, except 7.3L 34 25 —
Extension housing to case 41-54 30-40 —
Transmission insulator and retainer-to-case 81-108 60-80 —
Transmission insulator and retainer-to-crossmember (rear mount) 94 69 —
Torque converter-to-flexplate nut 35 26 —
Inner manual valve detent lever nut 47 35 —
Low/reverse OWC inner race to case 24-34 18-25 —
Line pressure to case — plug 8-16 6-12 —
Main and lower control body to case 9-11 — 80-100
Main accumulator and solenoid body to case 9-11 — 80-100
Digital transmission range sensor 8-10 — 75-85
Intermediate/overdrive cylinder fluid feed bolt (front) 16 12 —
Transmission pan to case 15 11 —
Pump body to case 24-31 18-23 —
Parking pawl abutment to case 25 18 —
Parking rod guide plate to case 25 18 —
Manual control valve detent lever spring to case 10 — 89
Reinforcing plate to case 9-11 — 80-100
Stator support to pump body 9-11 — 80-100
Transmission to engine 47 35 —
Transmission to engine (7.3L diesel) 61 45 —
Transmission support crossmember-to-frame 81 60 —
Output shaft speed (OSS) sensor 8-10 — 70-88
Turbine shaft speed (TSS) sensor 8-10 — 70-88
