I have a 1984 F-150 4X4 with the 300 I-6. It has a 4 speed manual transmission. Okay so here's the problem... my truck keeps burning up the ICM and Ignition coil. Ive replaced both of them twice within a one week period and they both burned up in less than 20 minutes of driving leaving me stranded. Ive had people tell me that it is grounding out but i have searched the truck and cant seem to find any bad grounds. Could a resistor be bad? any help is appreciated. (this truck has headers and a 4v Carb intake).
Measure the voltage on the coil + wire with the truck running. If it's 12 volts or higher, then someone has modified the wiring, and the resistor wire is missing from the harness.
Thanks. I am the only owner of the truck and have never modified any of the electrical wiring. Could it be a possibility that the resistor is wore out because its never been replaced and where would it be located at? Also, would you happen to know where the EEC is located?
I have a hard time nailing down when they did, and did not use electronic engine controls on some of these engines. Does your distributor have a vacuum line going to it? What does the underhood sticker say(EECIII, EECIV)?
In that case you probably do not have the resistor wiring. The TFI module uses the full 12 volts. One more question. Are you using the special white grease under the module?
Yes i am using the electrical grease that comes with ICM. According to the haynes manual...it says that there is a resistor (84 f15o with 300) on one of the wires that leads to the EEC from the ICM. It is associated with the ignition coil.
Napa has "heat sink compound" which is the best. It is white in color. I would not risk using the di-electric grease as it does NEED to have a good way to dissipate the heat. The old one most likey failed due to the lack of a good way to remove the heat from the module.
i dont think that the grease is causing the problem...i get my parts from carquest which are generally very good products. Im leaning more towards a bad resistor or bad wire. does anyone know where the ECC (computer) is located on a 84 f-150 with the 300 staight six?
Ive gone thru 2 brand new ICM's and ignition coils in a week...again the problem occurs when the truck is being drove...usaully goes out after about 15 minutes of consistent driving.
The computer is located above the gas peddle. It slides in a tray and is held in by one bolt. The harness will disconnect with one bolt in the middle of the wiring harness. I removed my computer and went back to duraspark ignition system.
The EEC IV uses full voltage to your coil, so if your ALT is putting out 14.5 volts that is what is going to the square coil... you do have a square coil and NOT a round one????
The resistor wire is still in your trucks wiring harness it is just not being used to feed the coil.
I really do believe that the ignition control module (ICM) that is bolted to the side of the dissy is getting to hot and thus failing. The ICM were moved onto a heat sink away from engine heat on latter models. You can get a used heat sink at a computer store that are used on CPU’s and mount the ICM to that, try to move it to a place with more air flow.
The part of this that does not make sense to me is the square coil failing also. How do you know the coil is failing? Did you have it tested at the auto parts store? Are you just changing both the coil and the ICM at the same time just to get the truck to run?
I bought a new duraspark distributor on Ebay for $50 from this guy. Item number: 370100430475<o></o> I really don’t recommend putting money into trying to fix an EEC IV system. For under a $100 you can get rid of the EEC IV and use a Duraspark vacuum advance distributor with a different ignition module. I was running my 86 F-150 I6 for years in a fixed timing mode (EEC IV) without ANY ignition advance and never did know it wasn’t working correctly. It seemed to run fine at the time… but it was losing MPG and engine power. After getting rid of the EEC IV my MPG went up 3 or so but the increase in engine power was really noticeable and I am currently still using the same feedback carb you have on your truck.
Search duraspark, DS2, DSII for more info on converting. I think your 1984 I6 could have had DS2 or EEC IV ignition… depending on what month it left the factory.
Well...ive decided to rid the truck of using any of the computer. Im going with the Mallory Uni-lite optical distributor. Im tired of fooling with the EEC-IV and personally, i believe the main cause is faulty wires that lead to the ICM in which i cant blame the truck, its 24 years old, wires get old and deterioate. WIth the new distributor, i will be able to run 3 wires, one hot, one to ignition, and one to the coil. There really is no purpose for the computer on this truck, all emmisions have been removed. I blame Ford for horribly designing the EEC-IV system, since the truck was bought in 84, it never ran "right" because of the computer. There were always carbuerator problems and i am not the only person complaining of this.
They worked good when new, but I agree when it gets old, there are too many things to go wrong, and the parts are too expensive. I believe a lot of these trucks would pollute less, by converting them over like you are going to do, instead of trying to run the old system that doesn't half work.
Man I have a few questions about that I have a 91 f150 5.0 l 2 wheel drive manual I keep frying my ECM ICM or rarely I will destroy my coil all this means is they will burn up or ruin it may last two weeks and may last day my last a year I don't know but either I'll go towards a stop sign push the clutch in and the truck will shut off and that's it or I will cut the truck off for the night and that's it there's no next day it has Friday one of those three has been destroyed I am a long lines of you you've given me an idea I hope you still have the truck and haven't converted it over to a carburetor yes the computer is crap but just trying to keep it oe so if you have any information at all on it the stuff you did I would greatly appreciate it and if I come across anything that can help you out maybe you have a buddy if you've already got it took care of is running into the same problem but y'all have given me a few ideas and places to check thank you again any information any is appreciated
