E4OD Shudder has Arrived...
Old Oct 24, 2008 | 09:34 AM
quicklook2's Avatar
quicklook2
sounds like the end may be near.
one more thing to try: product called 'shudder fixx'.
only 5 bucks and is worth a try.
do a search on web for what it is.
Old Oct 24, 2008 | 10:18 AM
benshere's Avatar
benshere
cooler lines
I just noticed that no one has answered your question about the leak, above the pan on the tranny (Including me ) Thats really where I was going when I mentioned the work on the header pipe and converter. The tranny cooler line fittings are on the passenger side above the pan (~2"). Best I recall is, one is closer to the bell and one closer to the tailshaft. Unless you shook those unions up, I kinda doubt they would just start leaking with an oil change-----but possible. With the pre-heater and converter so close to the tranny, you almost have to loosen them at the manifold to get enough clearance to even see the fittings.
Maybe (if you have a manual shift 4X4 xfer case) there will be a removable inspection plate on top of the tunnel so you can get to it from the top.
56/78/92EFFIE
Nov 10, 2016 01:53 PM
sukemecuke
Feb 16, 2013 09:09 PM
WuTang
Jan 31, 2012 11:13 AM
quaddriver
20
Nov 1, 2011 02:24 PM
Blackbronco
Dec 4, 2010 05:49 PM
