Need help with turbo blade.
Old Oct 17, 2008 | 07:09 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Hello all,
My friend has a 95 F 250 with the 7.3 and we are doing the 6637 and I looked at the turbo and saw it was all bend and there is play in the shaft. What should be his course of action for the cheapest way to get his truck back on the road.
Thanks
Nick and Hamburger
Old Oct 17, 2008 | 07:46 PM
Welk49's Avatar
Welk49
have someone rebuild the turbo or buy a reman turbo. You could also try ebay for a used turbo. How much play is actually in the turbo?
Old Oct 17, 2008 | 08:16 PM
weekendwarriorfsw32
Master of Strokes
How hard is it to rebuild a turbo
Old Oct 18, 2008 | 09:03 AM
Welk49's Avatar
Welk49
i have never rebuilt one so I couldn't tell you for sure, but I know they sell the rebuild kits for them.
Old Oct 18, 2008 | 09:49 AM
weekendwarriorfsw32
Master of Strokes
Ok a dump question but is my 01 7.3 and his 95 have the same intake blade?
Old Oct 18, 2008 | 09:52 AM
westcoastslider's Avatar
westcoastslider
No, they are different turbos all together.
Old Oct 18, 2008 | 09:56 AM
westcoastslider
How did the blades get bent? Do they scrape on the compressor housing when you spin it. You should check the shaft for play up/down and in/out. A small amount of play up and down is ok. It's just a bushing and some of the play will be taken up by oil pressure. There should be very little play in and out.
Old Oct 18, 2008 | 10:17 AM
tjbeggs's Avatar
tjbeggs
How much play does it have? The 01 compressor will fit but it of a different (little worse) design. The turbo's are easy to rebuild. You can get a rebuild kit for $100 with free balance but you have ship the center section out to have the balance done. Then a new compressor is around $85.
Some play side to side/up and down is normal as long as the compressor doesn't scrap the housing. There should be virtually no movement in and out. The spec is something like .008 of an inch.
I would buy all the parts from Ron't Turbo Shop on ebay. I have a rebuilt unit from him and it is top notch! Ron himself is top notch as he helped me greatly when my turbo went out.
here is the parts you would need all together but the listing is for the 99-03 so just ask him if he could put together the same thing for you year truck. The kit listed might be all the same parts but I am not certain. Either way call him. He was easy to get ahold either way.
eBay Motors: BANKS 99/03 7.3 POWERSTROKE TURBO TURBOCHARGER REBUILD (item 110300141163 end time Oct-22-08 09:46:52 PDT)
Old Oct 18, 2008 | 11:09 AM
weekendwarriorfsw32
Master of Strokes
The turbo wheel looks like it got hit with something in multiple places. Now it did have a K&N air filter in it so that might have caused it.
Old Oct 19, 2008 | 09:42 PM
weekendwarriorfsw32
Master of Strokes
One more question is there any other cheaper places to buy rebuild parts or is Ron the only one
Thanks
Nick
Old Oct 19, 2008 | 09:49 PM
tjbeggs's Avatar
tjbeggs
Ron's is the cheapest place I have found. Any of the site sponsors are $120 just for the rebuild kit plus the price of the wicked wheel compressor
Old Oct 19, 2008 | 10:14 PM
weekendwarriorfsw32
Master of Strokes
Ok another question. I only looked for play left to right not in and out and I will check that tomorrow, but if there isn't any play all I need is a new Compressor wheel right?
Old Oct 20, 2008 | 06:21 AM
tjbeggs's Avatar
tjbeggs
Correct if the play feels good (there will be some but it shouldn't hit the housing) then all you need is the compressor ($85).
Old Oct 20, 2008 | 12:32 PM
weekendwarriorfsw32
Master of Strokes
Wheres the best place to get that?
Old Oct 20, 2008 | 09:42 PM
tjbeggs's Avatar
tjbeggs
Same guys as the other stuff. Ron's Turbo Shop off eBay.
