E4OD coolant line question-flow direction
Old Oct 17, 2008 | 04:45 PM
fastfarmer's Avatar
fastfarmer
Does the fluid flow out the coolant line fitting on the front of the case and in the fitting at the rear, or out the rear and in the front?
Old Oct 17, 2008 | 10:28 PM
RP27G8G's Avatar
RP27G8G
I'll give you a bump....I'd like to know the same thing.
Old Oct 17, 2008 | 10:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It flows from the front of the case to the coolers and returns to the trans at the rear of the case.
Old Oct 18, 2008 | 08:24 AM
fastfarmer's Avatar
fastfarmer
Thanks Mark!
Old Oct 18, 2008 | 06:59 PM
lisagoud's Avatar
lisagoud
exactly correct!!!Now, for a trick question.,...Has this always been so with Ford auto trannys?
Old Oct 19, 2008 | 11:21 AM
Mark Kovalsky
No, not always. The AOD/4R70W has the lines one above the other, not front and rear.
Old Oct 19, 2008 | 12:37 PM
lisagoud's Avatar
lisagoud
thus the term 'trick question'...awesome job!!!
Mixer man
Jun 13, 2015 11:04 PM
tjmike
Jan 17, 2015 04:04 PM
chaser1602
Aug 7, 2014 06:48 PM
genscripter
May 4, 2014 07:50 PM
98EXPY 5-0
13
Oct 17, 2012 06:30 AM
