IAC questions
Old Feb 24, 2015 | 07:08 PM
lil'ford's Avatar
lil'ford
IAC questions
i found that my idle air control solenoid was the route to the majority of my problems and was curious on how i could possibly bench test it or clean it and possibly make it work.. or test one from the wreckers thnx.
Old Feb 24, 2015 | 11:35 PM
TexasGuy001's Avatar
TexasGuy001
This is a part that I would suggest just buying a new one.
Old Feb 25, 2015 | 09:12 AM
jas88's Avatar
jas88
I personally have never bought a new one. I clean em with throttle body cleaner and and old toothbrush - take it off the truck to do this. If you are gonna buy a new one, be sure to get a Motorcraft. The other replacements are junk in my experience.
Disconnect the battery while cleaning or replacing so you reset the computer. I can then take up to a week for the computer to re-learn the idle.
Old Feb 25, 2015 | 09:17 AM
Freightrain's Avatar
Freightrain
Yup, I bought a new one, didn't work any better then the old one.
Remove the old one, take it apart(two small screws)---mark the orientation of the two pieces by scribing them with screwdriver. Clean the valve portion with brake clean and blow it dry. Then do the same with the soleniod portion. Then a touch of PB blaster or such to lubricate it. You should be able to shake the soleniod and have it rattle easily.
Put it back together and install it.
I made the mistake of using oil to lubricate the soleniod, but when it got cold outside it would stick and not work right. I cleaned and used PB on it and it has worked flawless all winter(-20 weather).
Old Feb 25, 2015 | 09:25 AM
rla2005's Avatar
rla2005
Some good info here:
IAC Cleaning - FSB Forums
Fuel Injection Technical Library » Idle Air Bypass (IAB)
Old Feb 25, 2015 | 10:24 PM
TexasGuy001
I never had any luck cleaning and lubricating them. That was only a temporary fix. I get Motorcraft or BWD replacements.
Old Feb 25, 2015 | 10:29 PM
JWC 3's Avatar
JWC 3
I Agree , cleaning is a temporary "fix" ....
Old Feb 27, 2015 | 01:04 AM
lil'ford's Avatar
lil'ford
well i hosed it in carb cleaner and she runs prime now i finally got the 302 to idle at 600 and nicely lol.... it was gummed up with old dirty oil from my pcv that was leaking into my intake and making it smoke blue at high rpm's so 2 birds with one stone lol thnx guys cheers
Old Feb 27, 2015 | 08:05 AM
rla2005's Avatar
rla2005
Glad it worked out for you!
Old Feb 27, 2015 | 08:12 AM
Jaime74656's Avatar
Jaime74656
yay another issue fixed on the Ford!!! LOL! glad you got it sorted!
Old Mar 5, 2015 | 06:29 PM
lil'ford's Avatar
lil'ford
so the iac completely ***** itself and now it wont stay running with it plugged in but if i unplug it the truck starts rough but runs smooth. and i priced out the IAC solenoid and damn its steep its $200 after taxes so i was wondering how to bench test one at the wreckers
Old Mar 5, 2015 | 06:35 PM
rla2005's Avatar
rla2005
$200...where are you shopping?
Old Mar 5, 2015 | 07:27 PM
ncranchero's Avatar
ncranchero
http://www.ebay.com/itm/Motorcraft-CX1828-Idle-Air-Control-Motor-/390954150900?pt=Motors_Car_Truck_Parts_Accessories&hash=item5b06aeebf4&vxp=mtr#shpCntId
Old Mar 5, 2015 | 11:18 PM
lil'ford's Avatar
lil'ford
lol lordco summit racing is $39.99 plus like $20 in shipping and handling and then the U.S. to Canadian conversion so i'm in at least $70 but i might be able to find a newer one at the wreckers
Old Mar 5, 2015 | 11:22 PM
lil'ford's Avatar
lil'ford
so any one know how to bench test one if i can
