clearance light ?
Old Oct 16, 2008 | 09:58 PM
bakerbuilttracks's Avatar
bakerbuilttracks
clearance light ?
well i got my lights in the other day i read motomans install guide and have a few questions.
1. to hard wire into my parking lights so i dont haave to run a toggle switch where is a good place. motoman said something bout the passanger side kick pannel where at in their.
2. my lights have 2 mounting holes one on the left and one right side. so 3 total in the roof 2 mounting and 1 in the center for the wire any tips on making shure their stright and not crooked.
Old Oct 16, 2008 | 10:14 PM
jdecker88's Avatar
jdecker88
Cab Light Install Here you go the kicker is the last picture on the bottom left.
Old Oct 17, 2008 | 07:54 AM
03_PSD's Avatar
03_PSD
I installed my clearence lights last Sunday. I measured about 100 times and drilled once. Pics in gallery. Its a good idea to make a template. Once you get past the first hole it's a breeze. Best of luck!!
Old Oct 17, 2008 | 10:01 PM
bakerbuilttracks
thanks guys i may messs with it this weekend i got my lights from cabelas and are the same design as factory look but mount up a lil diffrent
Old Oct 17, 2008 | 10:12 PM
bigsteve1969's Avatar
bigsteve1969
i just dont know if i could drill in my roof! much less pull the headliner out
Old Oct 17, 2008 | 11:01 PM
bdrummonds's Avatar
bdrummonds
Bring it over one sat, and I'll help you do it.
Old Oct 18, 2008 | 09:49 AM
Ponyboychris's Avatar
Ponyboychris
Brandon, if I'm ever in Alabama or you make it up to Colorado, I'll lean on you for helping me installing a set.
Old Oct 18, 2008 | 03:28 PM
HKusp's Avatar
HKusp
Check my tech gallery and read motoman's stuff. It isn't too hard. I had to have my neighbor drill the holes. I just couldn't do it. We used a uni bit. Worked great.
Old Oct 18, 2008 | 03:36 PM
bigsteve1969
Watch out ill be there!
Old Oct 18, 2008 | 06:11 PM
bakerbuilttracks
haha brandon.... yea its only like 3 hrs but if i get all layed out and dont feel comfortable with it i might do that im gunna be in montgomery nov. 14 15 and 16 my uncle is gunna be racing his car on pinks. so... like i said i might take u up on that
Old Oct 18, 2008 | 07:25 PM
bdrummonds's Avatar
bdrummonds
Is that when Pinks is coming back??? I'll probably go and watch one of those days.
Shoot Ill bring a drill and a level and we can get it done in the parking lot.
Old Oct 18, 2008 | 09:40 PM
bigsteve1969
Maybe TS
Old Oct 18, 2008 | 10:58 PM
bdrummonds's Avatar
bdrummonds
Maybe TS
Steve, I am gonna be straight up honest with ya......... I dont plan on being able to drill a straight hole at TS, and plus you need to get this done before then, it really is simple. The hardest part is just starting the job.
I did not use a drift or center punch when I did mine, I used a sharpie and outlined all the bases (after I had it all measured) and then drilled the holes for the wiring to go through ( my truck is red so I used a red sharpie) the wiring is simple, Brown = +, Black = -. You will find a brown(running light positive) wire under the kick panel by the pax door ( solid brown wire is the universal color for running lights /parking lights in most vehicles)
If you want to come over and make a saturday of it, we can do your cab lights, and some other things if you want. I am full up until after Nov 8th with Cheerleading competitions (my two daughters each have games and competitions on Saturdays until then) but after that we can find a good weekend. I am about 70 miles from Tuscaloosa, straight down 82.
Old Oct 19, 2008 | 01:10 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Since there are several people who have installed cab/clearance lights, I ordered my set last Thursday. They will be here on Wednesday. Recon smoked lens with amber LED
Old Oct 19, 2008 | 05:39 PM
bigsteve1969
brandon i've already mapquested it ha ha we'll figure out a saturday towards end of nov. or first of dec. i know how schedules get full. i guess i'll have to order somethin to make it a full saturday those recon clearance lights pretty good? black on a black truck
