So how far off would it be if I have 285-70-17? Is it worth doing?
I used to have a '92 Bronco and I was able to adjust it using the trip reset button, I'm guessing that they must have changed that on newer trucks?
now a days every thing is done through the PCM.it will need to be programmed... sounds like your just changing rim size not tire size unless your running 265's right now...285's wont be that far off..maybe 3MPH
one of the few things my Hypertec was good for was speedo calibration
when I changed from 215-85 to 235-85 speedo was off about 5 mph and trans seemed to work better when speedo was calibrated
now with DP speedo is off about 5 mph again
Don't know if that has anything to do with goofy 1-2 upshift or not
