Sponsored by: Auxito
Window Regulator Replacement
Old Oct 15, 2008 | 07:10 PM
boatnfish's Avatar
boatnfish
Believe that I need to replace the window regulator on my 01 F150 4x4 supercab.
I might be able to get away with fixing a connection between the lift motor and regulator because I found a broken screw when I pulled the door panel to get an initial look.
Question is, are the rivets a special size, or will a standard 1/4 inch one fit and hold properly?
I am hoping that fixing the broken screw will fix the problem. The window stops about half way when going up. If I pull the window towards the rear of the truck (not up) it will finish going up just fine. When I pull the window towards the rear of the truck it will move (rock) between 1/4 and 1/2 inch.
Thanks
DanielC
Aerostar
Jan 16, 2011 01:51 AM
mfp4073
1983 - 2012 Ranger & B-Series
13
Jun 21, 2009 02:53 AM
boatnfish
1997 - 2003 F150
Mar 29, 2008 10:18 AM
FoMoColover
Aerostar
Oct 3, 2006 09:30 PM
BroncoBuster
1978 - 1996 Big Bronco
Jun 18, 2005 11:18 PM
