Engine Miss in Rain
Old Oct 15, 2008 | 10:36 AM
agtech's Avatar
agtech
Engine Miss in Rain
I was wondering if anyone had ever had a 7.3 that had a miss much like a cps going bad, but only when it rains. Truck runs fine when the sun is shining. I have replaced the cps once since this started but did not fix anything. My check engine light comes on sometimes when it misses, could a ford dealer maybee get a code off this that would lead me in the right direction? Thanks
Old Oct 15, 2008 | 10:46 AM
bc56845's Avatar
bc56845
We used to have a 2001 450 repo truck that did this in the rain. It was under warranty then, seems like I remember it had something to do with the accelerator pedal assembly
Old Oct 15, 2008 | 11:10 AM
rbaker6336's Avatar
rbaker6336
may be getting moisture in CPS plug
Old Oct 15, 2008 | 11:58 AM
Action4478's Avatar
Action4478
Windsheild or clearance lights leak?...
Code will help ...
Old Oct 15, 2008 | 02:05 PM
bc56845's Avatar
bc56845
Does it do it when you get in the truck with wet feet, or does it do it if it just starts raining going down the road?
Old Oct 17, 2008 | 07:30 AM
agtech's Avatar
agtech
Sorry I have't responded back yet, thanks for the info. It usually starts with just some rain outside. I don't usually have wet feet and my windshield has never leaked that I have noticed. Thanks
Old Oct 17, 2008 | 01:02 PM
wlihntr's Avatar
wlihntr
i have heard of this problem before if i remember correctly it had too do with the IDM (injector drive module) getting wet.
Old Oct 17, 2008 | 01:35 PM
ron's power stroke's Avatar
ron's power stroke
my guess would be CPS plug...go to a parts store and get some electrical grease in a tube and electrical cleaner in a spray can..its made for sensors and light bulbs on your truck...pull the plug off of the CPS and spray the cleaner in the socket of the plug to chase out any moisture..shake the plug good to get the cleaner out..it is fast drying but make sure its dry.make sure the rubber weather ring is in the socket or maybe stuck in the sensor...then put a dab of grease in the socket and plug it back in...you can do this to the IDM as well...I do this every electrical socket on my truck
90pioneer
26
Mar 13, 2019 09:05 AM
cabloom300
Dec 3, 2014 04:18 PM
DKF350
Nov 3, 2011 08:26 PM
lifted77f250
Aug 27, 2008 11:48 PM
Rentman
Jul 3, 2006 08:03 PM
