Offroad & 4x4
Body Lifts
Old Jun 19, 2000 | 01:33 PM
old timer's Avatar
old timer
Body Lifts
Well I just finished installing a 6in. Pro-comp suspension lift. I went to measure the height all around, to make sure it's sitting level, and all the sides are different by a little. Well this is a 1980 F-150 and I noticed that my stock rubber body bushings are shot. I think this is my problem, so instead of just replacing the bushings with stock ones, I might as well just install a body lift.
Ok here's the question. If I get a 3in. lift, with bumper relocation kit, is there anything else that has to be modified for this to work properly. My truck has a 4-speed floor shift, as well as floor shift for the transfer case. I guess those two items are my main concern.
Old Jun 19, 2000 | 03:43 PM
Nathan's Avatar
Nathan
Body Lifts
I would forget the body lift. There is too much to mess with like clutch and shifter linkage, extending wire harnesses, fan shroud, brake lines, pretty much anything connected to both body and frame. Plus, I hat to see the frame below the body, and the gap in the rear fender wells. Just get new Poly bushings and put em in. You might regret getting a body lift.
Nathan
Old Jun 19, 2000 | 04:28 PM
old timer's Avatar
old timer
Body Lifts
Wow, I knew some things had to be adapted, but forget all that. I'm happy with the height of my truck now. Stock height poly bushing seem like the way to go.
Any ideas on who sells them.
thanks
Old Jun 20, 2000 | 05:44 AM
Nathan's Avatar
Nathan
Body Lifts
JC Whitney sells them I think. Any off-road shop should have or be able to get them. Good luck!
Nathan
Old Jun 20, 2000 | 04:52 PM
Ford79's Avatar
Ford79
Body Lifts
BeerCan500
Nov 25, 2012 05:14 PM
Red Cobra
Jul 31, 2011 06:30 PM
YoungMT Hick
Offroad & 4x4
Apr 27, 2011 12:23 AM
impact
Offroad & 4x4
Oct 25, 2002 12:18 AM
moose4130
1966 - 1977 Early Broncos
May 3, 2002 11:25 PM
