Fuel Pressure Guage
Old Oct 14, 2008 | 10:01 PM
nissandoc's Avatar
nissandoc
Fuel Pressure Guage
So I've been looking for a fuel pressure guage setup since I seen a pic of Brandons (Bdrummonds) in another thread. Problem is that I cant find a liquid filled guage in 2 1/16. They are all either electric or no liquid. This is the mount I would like to use if possible: The isspro r7602 Universal Gauge Mounts at DieselManor
Is anyone using and electric guage? And how acurate are they?
Anyone using an isolator and does it work ok?
Old Oct 14, 2008 | 10:28 PM
bdrummonds's Avatar
bdrummonds
Darrell, here is a link to a 2.5 inch glycerin filled gauge. look down the list and you will see a 0-100psi
I know the holder you are looking at is 2 1/16, but it could probably be trimmed to fit the larger guage.
Rear-Mounted Pressure Gauges
Old Oct 14, 2008 | 10:35 PM
Pocket's Avatar
Pocket
I have an electric gauge and it's very accurate. The isolator is mounted on my regulator. Mine is the DiPricol Optix.
Old Oct 14, 2008 | 11:02 PM
nissandoc's Avatar
nissandoc
Brandon, that would be a cool looking guage on the cowl but would probably have to use homemade bracket, which is ok. I'm trying to figure out the best overall price, cool effect and clean install as possible. I think that cowl mounted with some low light illumination at night would be the best "cool effect" but would have to go electric, and that brings the question of how it would hold up in the weather.
Curtis, do you get any vibration of the needle? And I'm assuming that its mounted inside the cab?
Old Oct 14, 2008 | 11:08 PM
Pocket's Avatar
Pocket
Zero vibration at the needle. I used to have a liquid filled gauge under the hood, and when I swapped to the DiPricol it showed the same pressure as the old one.
And yes, it is mounted in the cab on the pillar.
Old Oct 14, 2008 | 11:18 PM
nissandoc's Avatar
nissandoc
Does it use clear tubing sorta like the boost tube from the isolator to the guage?
Old Oct 15, 2008 | 12:03 AM
Pocket's Avatar
Pocket
No, the isolator mounts directly to the fuel source, and you just plug an electrical harness into the isolator. You can get an adapter and mount the isolator to the back of the stock fuel bowl. I already did the regulated return on my truck, so I just put the isolator on the regulator itself since it was a direct bolt on.
Old Oct 15, 2008 | 04:44 AM
ron's power stroke's Avatar
ron's power stroke
20 bucks for a gauge at ITP and 50 cents worth of 1 1/2 inch PVC will get you this look..click on pic to see how...
Old Oct 15, 2008 | 07:53 AM
Ponyboychris's Avatar
Ponyboychris
Here's the link for Ron's gauge. This is on my "must have" wish list.
Liquid Filled Pressure Gauge
Old Oct 15, 2008 | 02:05 PM
aklim's Avatar
aklim
I had installed 3 gauges. 2 from Summit and 1 from ITP and both of them failed after a while. Supposedly it is pretty hard on them in the engine compartment. Anyone have a gauge that held for a long period of time and how long?
Old Oct 15, 2008 | 03:11 PM
smoky_diesel's Avatar
smoky_diesel
I used an old-school gauge cup from another project. if you are careful it will clear the hood, wiper and still have a good viewing angle. I did not have to drill any holes or cut anything to mount it.
The autometer gauge worked fine for many years until I used it on this diesel. now it's junk.
I used to use it with a mechanical isolator but never got it to work properly, and I'm pretty f'n persistent. Waste of $100. Should have got a electrical gauge in the first place.
now that I have fixed my fuel problems I don't need the incorrectly reading gauge, but can you ever have too many guages? it looks cool anyway.
Old Oct 15, 2008 | 04:08 PM
bdrummonds's Avatar
bdrummonds
My marshall guage rode under my hood(on a bracket off of the alt.) for a year, and has now been on the outside for a year, and it is still fine. Y'all have all seen pics so I wont repost, if you do want to see my setup its in my gallery.
