Sponsored by: Real Truck
Front Sway Bar End Link Install
Old Oct 14, 2008 | 07:31 PM
wilbur996's Avatar
wilbur996
Unhappy Front Sway Bar End Link Install
Got a 99 F-350 4x4 and I was replacing the end links on the front sway bar and something just dosen't look right.
Question. Does the stud on the end link point in toward the center of the truck or does it point out? This is the frame mount for the end link. If they point in, the end link is positioned under the frame rail with about an 1/8" of clearance between the top of the end link and the frame. If the stud points toward the outside of the truck there is plenty of clearance cause the end link is between the frame rails but the end links don't really install straight.
When I took it apart the end links were installed with the stud pointing in toward the center so the top of the end link was under the frame rail with about no clearance.
Does this make sense?
Thanks
Old Oct 14, 2008 | 07:43 PM
riggz's Avatar
riggz
I'm pretty sure both studs point outwards. At least they do on my 04 F250.
Old Oct 14, 2008 | 07:57 PM
wilbur996's Avatar
wilbur996
Riggz,
Thanks! That's a big help. I thought that was better than the previous install.
Now the bottom part of the end link that attaches to the sway bar. They seem to fit best on the inside of the sway bar. Is that correct.
Appreciate the help.
Thanks!
Old Oct 14, 2008 | 09:13 PM
riggz's Avatar
riggz
I can't remember if they mount inside or out. I'll try to remember to check on my way out in the morning.
Old Oct 14, 2008 | 10:12 PM
1975StroppeBaja's Avatar
1975StroppeBaja
On mine, the nuts face outboard on top and bottom.
Old Oct 15, 2008 | 03:13 PM
riggz's Avatar
riggz
Ok after looking at my truck it goes like this from the center of the truck outwards:
bolt - end link - sway bar - nut
Old Oct 18, 2008 | 07:39 PM
wilbur996's Avatar
wilbur996
Thanks! That's the way I got installed. It was installed incorrectly previously.
Old Oct 19, 2008 | 07:50 AM
riggz's Avatar
riggz
Doh! Glad you got it sorted out.
VaHkGuy
Nov 12, 2020 06:58 PM
sammie0126
Aug 9, 2016 03:28 PM
ahuggins6
2004 - 2008 F150
Apr 17, 2013 07:08 AM
mwjust
Apr 2, 2012 08:49 AM
Christopher2
Jan 4, 2005 12:36 PM
